DIY!!Bulb repacement for heater control unit!!!
Old Feb 7, 2010 | 01:48 PM
Haulin_Ls4_GxP's Avatar
Default DIY!!Bulb repacement for heater control unit!!!
Ok so I just got my Gxp and it had 3 bulbs out in the heater control unit. If any of you have had the unit apart you know the bulb are soldered in, and the dealer doesn't offer a replacement bulb. Just the whole unit at a cool $360 . these bulb weren't that important to me so I thought I would try to replace them myself. go to Radio Shack and get bulbs 272-1154. These bulbs a bit smaller than the factory bulbs but I promise they work just fine. you'll also need some de-solder wick(aka chem. wick) and a solder iron. There is a total of 4 bulbs that you can use the new bulbs on. There are more bulb than this but I have yet to fine a replacement that will work. I don't have any pictures yet but when I get home I will get some posted. Also you do not need to be a pro in soldering to do the I am by no means a pro and all my stuff still works fine.
Old Feb 7, 2010 | 02:25 PM
GXP25's Avatar
Yup!
Part: 12V/50mA Incandescent Bulb - RadioShack.com
The reviews speak for themselves.
Old Feb 7, 2010 | 03:44 PM
TiredGXP's Avatar
Timely thread, Just had some more go out on mine.
Thanks for the link.
:cheers
Old Feb 12, 2010 | 11:34 AM
roadrash187's Avatar
I went and used these bulbs for all, except the ones that have the blue covering. So far no problems, and everything is lit up pretty good.
Old Feb 12, 2010 | 03:29 PM
They also work fine on the blue bulbs as well.
