brake job
Old Mar 21, 2010 | 09:28 AM
bigalnash's Avatar
Default brake job
changing all 4 pads and rotors on my gxp anyone know the all the tools i need to do so? or where i can find that information?
Old Mar 21, 2010 | 10:22 AM
monte_with_a_LS4's Avatar
its not too hard. Just need a 3/4 socket to take your wheels off. And torque them at 100lbs when u put them back on. I cant rebember what size of socket you need for the calipers but theres just 2 bolts on the back that you unscrew and those slide off. On my car the bolts on the front callipers were 1 mm bigger than the back callipers. then just use a allen wrench on the screw that holds on each rotor. If it doesnt just slide off hit it with a rubber hammer a couple of times. Good Luck hope that helps.
Old Mar 21, 2010 | 11:50 AM
texasGXP08's Avatar
It is very easy to do. If you have a basic socket set and allen wrench you will be fine. I do not remember the exact size of the tools I used but I know they were nothing out of the ordinary. Oh, and don't forget a C-clamp to compress the caliper pistons.
This link isn't a write-up but proof a novice (myself) can handle the job with ease.
https://ls1tech.com/forums/ls4-front...es-update.html
Old Mar 21, 2010 | 04:39 PM
jabronie78's Avatar
I thought it was a hex not a allen screw.
Old Mar 21, 2010 | 04:56 PM
texasGXP08's Avatar
You are correct. I have looked back through my pictures and I can see that I had my torx bits out. I probably shouldn't be commenting on technical aspects of this from memory... I PROMISE IT IS EASY!
Old Mar 21, 2010 | 07:12 PM
yea sorry it is hex i couldnt remember the name. I know i used the hex scew drivers to unscrew them though
