Monte SS factory navigation retrofit?
Old Apr 9, 2010 | 11:12 PM
2006 Silver Monte SS's Avatar
Default Monte SS factory navigation retrofit?
Saw one for sale in the classified section recently and wondered if anyone has done this mod...Looked like a factory install.
Old Apr 9, 2010 | 11:19 PM
monte_with_a_LS4's Avatar
someone has on here but i cant remember who. it was a impala i know that
Old Apr 9, 2010 | 11:38 PM
mike690003's Avatar
Quite do-able: http://www.naioa.com/v2/modules.php?...oem+navigation
Old Apr 10, 2010 | 12:24 AM
Do we have Bose in the Montes? I have a factory amp under my rear parcel deck...If I don't have Bose, is there still a factory type of way to do it right?
Old Apr 10, 2010 | 12:30 AM
Neanderthal's Avatar
I have the nav/bose/$2000 factory unit. POS IMHO, but have at it.
Or you can spend 200-500 bucks and get a good aftermarket setup.
Old Apr 10, 2010 | 07:57 AM
91LT16SpeedFormula's Avatar
You would be better with an aftermarket setup for the money,better quality and sound
Old Apr 10, 2010 | 07:26 PM
mike690003's Avatar
Montes have the Bose amp, it's just not as well advertised as the impalas.
Old Apr 10, 2010 | 07:38 PM
Nick_Nasty's_GXP's Avatar
Hey did you get the trunk mat??
Old Apr 10, 2010 | 08:40 PM
GXP25's Avatar
You mean the Monsoon amplifier.
The corvettes have the Bose amplifier with the NAV unit, we have the Monsoon amplifier with the same NAV unit.
Old Apr 11, 2010 | 02:36 AM
teamfbody's Avatar
i'll opt 4 the double din dvd/nav
Old Apr 12, 2010 | 01:41 PM
LS1 Racing's Avatar
The unit in the GXPs is different than the one in the Chevys. The 06-up Impala/Monte have 29-bit CAN which allows for the usage of the newer factory radios. To my knowledge, the Grand Prix never received this upgrade, thus, I can understand why you feel that way about yours!
I was the one who posted the "How-To" and have done the coversion myself. I can tell you that it costs a lot more then $500 to get a decent aftermarket in-dash Nav system. Most new HUs start at around $600, you'll spend another $50 or so in a mounting kit and harness adapter, PLUS, it's another $150 or $200 if you want to retain SWC and OnStar, as well as your turn-signal chimes, etc.
My car came with Bose, and I payed $485 for the Nav unit that came with the map disc and antenna, spent another $25 for the VSS harness (admittedly no longer available through JP Customs), and spent another $50 on dealer TechII programming. So, for under $600, I have a factory system that may lack a few features of aftermarket HUs, but works flawlessly with the factory accessories and is less of a theft target.
It's also never given me a wrong a turn, and voice guidance chick sounds kinda hot (though my wife may disagree!).
Old Apr 12, 2010 | 05:27 PM
Nacho SS's Avatar
hahaha That's hilarious.
Old Apr 13, 2010 | 03:52 PM
RickAKATed10's Avatar
I love this mod and I really want to do it. What is a VSS harness?
Old Apr 13, 2010 | 04:57 PM
LS1 Racing's Avatar
A VSS harness attaches to connector #4 on the back of the stock radio. It has one wire that connects to the Vehicle Speed Sensor (VSS) wire under the hood so that the Nav will still track even if you lose signal for a while. You also need it for the voice guidance to work.
It's pretty easy to make your own VSS wire, since the company that sold them for $25 went under.
