Removing LS4 harmonic dampner
Old Apr 17, 2010 | 03:21 PM
txcarbuilder's Avatar
Default Removing LS4 harmonic dampner
I need to pull the harmonic dampner from an LS4. Does anybody know what sort of puller GM recommends for this job? These don't have threaded holes in them to use a regular puller.
Old Apr 17, 2010 | 05:37 PM
neilownz's Avatar
EN 47699 flywheel holding tool
J 41665 crankshaft balancer and sprocket installer
J 41816 crankshaft balancer remover
J 41816-2 crankshaft end protector
J 42640 steering column anti-rotation pin
J 45059 torque angle meter
Pages 9-1640 to 9-1645
Old Apr 17, 2010 | 05:52 PM
Mels SS's Avatar
Why do you need to pull the dampner?
Old Apr 17, 2010 | 06:27 PM
neilownz's Avatar
I think they stopped making them if it was broke or something. Nobody has figured out the similar part, but those pullers come up for other vehicles that might have the same balancer.
Maybe a cam swap.
Old Apr 17, 2010 | 10:10 PM
Mels SS's Avatar
Glad I purchased and extra one.
Old Apr 18, 2010 | 02:50 PM
I am pulling it to install it on an LS1 that is going into a Porsche Boxster. I have made an adapter to mount the engine to the transmission and I am putting the LS4 parts on the front to make the engine as short as possible. I will be using the LS4 dampner and water pump with the Porsche alternator, P/S pump, and A/C compressor.
Does anybody have a photo, or know here I can find one, of the puller? I assume that it fits into the holes in the pulley to pull it since there are no tapped holes to bolt to like most balancers have.
