Help with wiring diagrams
Old Apr 21, 2010 | 10:22 AM
07SSport's Avatar
Default Help with wiring diagrams
I recently purchased two front buckets out of an 04 Grand Prix to put in my 07 ISS... you GP guys definitley got the better end of the deal in the comfort department, no question.
The issue Im having is that the Impala driver seat is power-recline, and the GP seat is manual recline (everything else is power). In order for me to make this GP seat work, I will need to rewire the plug so that it plugs in to the Impala wiring. Can anyone help me with this? Do I need a wiring diagram to pull this off successfully?
Thanks in advance!
Old Apr 21, 2010 | 01:00 PM
StealthV8's Avatar
A wiring diagram would help but you may just be able to use a multimeter (or even a fuse tester light) and figure out what wire controls what action. How many wires we talking about here?
Old Apr 21, 2010 | 02:24 PM
07SSport's Avatar
Well the male connector on the GP has 3 prongs, the Impala has 4 (or 5... i forget). The plug is the same but the spot where the prongs come out are different on each setup, so I will need to re-route the wires correctly.
