New Battery and Painted engine cover
Old May 5, 2010 | 08:55 PM
ATLterrell's Avatar
Default New Battery and Painted engine cover
Hi guys.. so today my battery died. I went and picked up an optima yellow top from advanced auto, and it came with 36 month warranty. The battery was a PITAto install, but after about 5 hrs working on it in advanced autos parking lot (b/c it wouldnt jump) i finally got it in. I thought i would post some pics of it with my newly painted engine cover.
Old May 5, 2010 | 11:02 PM
07carlocrusader's Avatar
Looks good, real good!! Now tell me,...how much fun was it to take out the old battery and put in the new one? Lol!!!
Old May 5, 2010 | 11:07 PM
TheMonteMan's Avatar
it does look good. 5 hours? jeez and i thought i took a long time to do mine. in your defense gm definitely built the car around that battery its ridiculous.
Old May 5, 2010 | 11:46 PM
Z28 Autobot's Avatar
I like it!!
Old May 5, 2010 | 11:54 PM
Mels SS's Avatar
Is that the new Battery in the pic? Engine cover looks good
Old May 6, 2010 | 03:24 AM
ATLterrell's Avatar
thanks guys....Yes thats the new battery in the pic.....and yhea that battery was the hardest battery ive ever had to replace on a car ever. But it finally got easier once i figured out how to unbolt and shift the the fuse box (boy did i feel like a dumb ***).. But i was happy in end the end b/c it was starting to get dark in the parking lot.LOLOL.
Old May 6, 2010 | 04:58 AM
Tappeter's Avatar
I had to replace the battery in my Monte a few weeks ago. It didn't take 5 hours,maybe 45 minutes, but I knew about the fuse box having to be moved, however the fuse box did not move very much, it was restrained by the cables coming out of it, they were fairly tight. I had to use some prayer and pull harder on the box and cables then I liked to move it enough to get battery out. I tied a rope to loop on end of battery to get a better grip. It finally squeezed out sideways. I also had a tough time finding a replacement battery around here, no one had the size (size 34 I believe) I needed. I wound up putting in a different size, it was same battery terminal arrangement, higher amps, same width and length but a little shorter, which actually made it easier to put in.
Old May 6, 2010 | 07:24 AM
94ss06gxp's Avatar
took me about 30 min to take out at put the red top in. But i read alot of prior battery install posts before i did mine.
Old May 6, 2010 | 09:45 AM
JP07GXP's Avatar
Which paint did you use on your engine cover? I used high temp paint and primed first but it doesnt look great. I want to take this paint off and sand it and redo it.
Old May 6, 2010 | 10:02 AM
94ss06gxp's Avatar
this guys user name threw me off lol, i seen the JP & GXP then seen a white gxp in the pic and i thought what did JP spray bomb his car white? lol sorry , welcome JP07GXP
Old May 6, 2010 | 11:32 AM
RickAKATed10's Avatar
Looks good.
Old May 7, 2010 | 12:04 AM
ATLterrell's Avatar
the paint i used was RUSTOLEUM HIGH HEAT ENGINE ENAMEL (ford red).. first i wet sanded it and then i painted it. No primer, sticks good though. Im probably going to take both the cover and strut braces off and try to clear coat them before they start to chip.
Old May 7, 2010 | 01:20 AM
williamGT's Avatar
lol, me too, I was like WTF....welcome JP07GXP
Old May 8, 2010 | 10:31 AM
JP07GXP's Avatar
Thanks guys. Yeah I think I used rustoleum but I guess I didnt sand the first time. That layer peeled then I sanded and re painted. Looks decent but I want to give it another shot. Painting is not a strong point for me. Getting better though. Yours looks professional. Soon as I seen that I was like gotta redo
Old May 8, 2010 | 05:39 PM
Mels SS's Avatar
I used high heat paint and clear
And its hanging on the wall in my garage, I went in another direction.
Old May 8, 2010 | 05:47 PM
mike690003's Avatar
Hey Mel,
what did you apply on the letters to keep them silver?
or did you repaint the letters in silver?
Old May 8, 2010 | 10:42 PM
Mels SS's Avatar
Vaseline!!
Old May 9, 2010 | 12:15 AM
ATLterrell's Avatar
hey MEL SS I never though about using VASELINE to cover the letters. Wish i would have thought of that. It took me about 3 to 4 hours to tape and cut the out lines of my letters with a razor blade, it was so time consuming.
Old May 9, 2010 | 01:04 AM
CenTexSS's Avatar
That's old for a new battery lol 9/09
Old May 9, 2010 | 01:22 AM
monte_with_a_LS4's Avatar
its hard to get out cuz the big v8s in the way lol
