06 Impalla SS; O2 sensor locations...
Old Jun 2, 2010 | 02:06 AM
NJLT1SS's Avatar
Default 06 Impalla SS; O2 sensor locations...
My bro has an 06 Impalla SS, with 30K miles on it, bone stock. Car has been running a little rough, and got a check engine light today. We pulled the codes with VCM Scanner from HP Tuners, and this is what we got:
P0300 - Engine misfire
P0301 - Missfire in cylinder 1
Also, this is what we are getting for Bank 1 and Bank 2 injectors:
INJ B1 - 2.6
O2 B1 - 117
INJ B2 - 0
O2 B2 - 0
LT B1 - 7.8
ST B1 - -0.8
ST B2 - (-100)
LT B2 - (-100)
Now this would tell me that bank 2 O2 sensor is dead. I was looking for the O2 sensor locations on this thing, and I can't find them. Should there be 1 for each bank of cylinders? I have seen a few posts here about doing the plugs and wires. Is that necessary with only 30K miles?
Nick
Old Jun 2, 2010 | 03:35 AM
07carlocrusader's Avatar
there are two.....one on the back manifold, before the flange of the downpipe and one after the cat, on the downpipe....
Old Jun 2, 2010 | 05:13 AM
Ill_Born_ss's Avatar
The LS4 only has O2 sensors in the Bank 1 side (front and rear), so dont worry about the numbers that you see for bank 2.
Just clean your MAF sensor and throttle body properly and your problem will go away.
Old Jun 2, 2010 | 06:02 AM
2005gxp's Avatar
swap the cyl 1 coil with another cyl. and see if the missfire follows, if it dosent, do plugs and wires.
Old Jun 2, 2010 | 08:02 AM
06MonteSS's Avatar
LS1Tech Sponsor
yeah, there is no "bank 2" on our cars... there is only 1 bank...
one exhaust pipe, one cat conv.... so only one bank...
bank 1 sensor 1 is the O2 sensor before the cat... bank 1 sensor 2 is the O2 sensor after the cat...
if we had dual exhaust, then we would have a bank 1 and a bank 2... but we don't...
so you will never get any data for anything you log for bank 2...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jan 28, 2013 | 07:52 PM
08 pimpala ss's Avatar
i have a 08 impala ss and already have a catback exhaust and am about to order a DP with out a cat should eliminate the rear o2 or keep it i also have a intune tuner so i should be able to turn the cat off i hope i do not want a idiot light. thanks
Old Jan 28, 2013 | 08:20 PM
91parkave's Avatar
Moderator
intune wont turn off the light, you can clear it but it will come right back youll need to get it tuned out.
