A/C not cold enuff
Old Jun 25, 2010 | 07:05 PM
bh04's Avatar
Default A/C not cold enuff
Title says it all. It's not blowing cold like it used to. Any suggestions on what I can do without taking it to a dealership?
Oh and tuesday the 29th, my rack and pinion get's replaced. My car is leaking power steering fluid pretty bad. Oh and since i'm broke at the moment I can't dish out the $690.....so I only have to pay $300.
Old Jun 25, 2010 | 07:21 PM
laytoncamaroz28's Avatar
It could be alot of things. It could be low on refridgerant or a bad sensor or a bad compressor. The easiest way to find out is to put ac gauges on the system to see what it is doing.
Old Jun 25, 2010 | 11:03 PM
bh04's Avatar
How would I go about putting ac gauges on the vehic?
Old Jun 27, 2010 | 12:32 PM
bh04's Avatar
Can anyone help me with the ac gauges? Where do I find some
Old Jun 27, 2010 | 01:15 PM
any mechanic shop will have em. thats really the only way you can check for the problem
Old Jun 27, 2010 | 01:30 PM
Ill_Born_ss's Avatar
Do you have/or know anybody with a Trinity or a Predator, because you can check it with one of them! Or even a tech II
Old Jun 27, 2010 | 03:14 PM
JDMC5's Avatar
unless you know what your doing with a/c systems I wouldn't recommend messing around with it. However, you can get a decent set of manifold gauges from harbour freight for 50 bucks. Most likely you have a leak and you are low on R-134a. You can buy cans of refrigerant with uv dye in them that will come out the leak and then you can use a uv light to find the leak. Worked great in my car. Ended up being the condenser, then the compressor. All said and done I'm now an a/c expert.
