Oil Burning Issue
This whole thread reminds me of my snow drifting experience this past winter. Got the soul of a rally driver...
If that oil's got water in it and you're driving it, holla atcha bearings.
I have a wedding today so no time to upload them. Will do tomorrow.
Thanks,
John
Checking the PCV tubes takes a couple seconds and is probably worth your time. If they look like they are full of a waxy oil and water emulsion, then clean them and check for blockages in the baffle.
Crazy flash flooding pic too, by the way!
My car has gone through barrels in it's life. My OLM was at 73% when the low oil light came on last. Two quarts of oil are still cheaper than a new car, but that's the only gripe I have about it.
When I had a blown head gasket in an old car the dipstick looked like it had vaseline on it.
Thanks.
It is 90/94 aka the Day Ryan on its way into the city.
I did a full change including filter.
I have noticed that the car appears to not settle into the 600-650 rpm idle. Looks like about 750 or maybe 800..?
Sorry I don't have a scan tool to check it, and yes I realize the gauge is far from exact.
For comparison I got this from another local GXP driver:
I do remember the car idling a bit lower before...
Every 50K I add 1 qt. And every oil change I seafoam everything.
Yeah I know the PCV sucks, that is why I installed a catch can, but I also know that isn't to blame, as far as I can tell, because it was high before that.
I also have this mysterious whistle coming from the back side of the motor on the TB side. That could be something that has always been there as I do not spend too much time under the hood of my car while it is running.
John
The higher idle is my newest concern, though I probably need a scan tool to verify it is high as I would not consider the tach the most accurate piece of machinery.
I did check another way and my car cruises at 50 mph at or below 1500 rpm, just like it always has.
I do not particularly know what has to do with vacuum back there so this will be an adventure!
Wind from the S (170 degrees) at 13 MPH (11 KT)
Visibility 9 mile(s)
Sky conditions partly cloudy
Weather Towering cumulus clouds observed
Temperature 98.1 F (36.7 C)
Heat index 109.6 F (43.1 C)
Dew Point 73.9 F (23.3 C)
Relative Humidity 46%
Pressure (altimeter) 29.75 in. Hg (1007 hPa)
