Tranny Cooler Installed - PITA
-Mike
Mgpeagle is right though, getting the cooler in place was tough, but running the lines and hooking them up was even harder. One, you either drill to make room for the lines, which is fine. Or, you buy enough line to run a crazy length around the radiator back to the tranny cooling lines. AND THEN, the factory cooling lines have almost no slack in them. So when you cut, be sure you can get at them. My problem was that my hands are huge, so slicing the lines and tightening down the clamps went painfully slow. I did get it done though, and it does work as advertised.
This is off another members car but it's a great write up. Click on each pic and it will give you instructions on what to do.
-Mike
haha
