LS4 and T-56?
Old Aug 12, 2010 | 03:06 PM
emonster6x's Avatar
Exclamation LS4 and T-56?
I want to build a Monster Miata, and I would like to know if the LS4 motor and be used conventially? That is, can you put a Clutch/Manual Tranny on them? They are cheaper online to buy and the HP #'s are good!
I also own a 2006 Impala SS and like the motor!
Old Aug 12, 2010 | 03:13 PM
EmersonHart13's Avatar
Miata is RWD so you would be better off looking at LS1/LS2/LS3/LS7... Or if you really like the 5.3 get the truck motor.
Old Aug 12, 2010 | 03:15 PM
StealthV8's Avatar
https://ls1tech.com/forums/ls4-front...onversion.html
read this and check out the links
Old Aug 12, 2010 | 03:16 PM
emonster6x's Avatar
OK, Got it, it ain't gonna work! Thanx!
Old Aug 12, 2010 | 03:24 PM
AlabamaGuy's Avatar
LS4 has the v6 bolt pattern. You could use an adapter but I'm pretty sure the only other difference is the trans mounted starter boss.
Old Aug 12, 2010 | 05:04 PM
JDMC5's Avatar
they're rwd, so the ls4 is a bad idea, any other ls based v8 would be a better choice. I saw an episode of gears where they installed a 5.0 in one.
Old Aug 12, 2010 | 05:18 PM
fieroguru's Avatar
The LS4 has the RWD dowel pins installed (or atleast mine does) but I haven't check to see if there is sufficient material for the RWD bolt hole locations. If there is, you could drill/tap the holes and bolt up a RWD tranny.
The RWD bellhousing flange is also about 1/4" deeper into the block than the FWD pattern, so you will loose about 1/4" of effective bellhousing depth due to this. However, you also gain back about 10 mm due to the shorter LS4 crank... so you should end up with slightly more bellhousing depth/clutch room.
Mounting the starter would still be an issue, but is much easier with the 168 tooth RWD flywheel vs the LS4 142 tooth flex plate. If you had a flat plate between the engine/tranny you could run a face mounted starter.
Whether all this work would be worth it... depends entirely on the person and the projet goals.
If you wanted to switch to the 5 speed behind the 3800 camaros (4th gen), it would have the same bellhousing as the LS4 and would use a 142 tooth flywheel. The starter would almost have to go under the oil pan, but again it would be an option.
Old Aug 12, 2010 | 05:47 PM
Hawkins04's Avatar
i have also seen a 350 put in the miata and the 5.0 miata on gears
Old Aug 12, 2010 | 08:03 PM
AlabamaGuy's Avatar
For the price of an LS1, there's really no reason to do an LS4.
Old Aug 12, 2010 | 08:08 PM
JDMC5's Avatar
I agree, why making it more difficult?
Old Aug 12, 2010 | 08:10 PM
AlabamaGuy's Avatar
I dunno.
Hell, in a car that light it'd be cool to buy a LS1/2 and do a 4.8L crank in it with a 102/102 or a Vic Jr with a top mount TB and a whole lot of cam...
Old Aug 12, 2010 | 09:43 PM
LS1 is surely the way to go.
Old Aug 12, 2010 | 10:24 PM
CenTexSS's Avatar
We have a local with LS2 in the last generation RX-7, I've been wanting to see it run.
Old Aug 13, 2010 | 07:01 AM
indynotch50's Avatar
We have so many LSx RX-7s running around Indy it's getting ridiculous.
To the OP, if you're doing a swap into a miata, use a termi setup!
Old Aug 13, 2010 | 09:31 AM
AlabamaGuy's Avatar
Does the DOHC motor fit in a miata?
Old Aug 13, 2010 | 11:49 AM
That's a good question. Enough so that i'm going to do some research and find out.
I'm just not a fan of hybrids... Except for the camaro / dohc swap I want to do...
Old Aug 13, 2010 | 03:04 PM
emonster6x's Avatar
what's a termi setup?
Old Aug 13, 2010 | 05:42 PM
Slow94Formula's Avatar
I'm going guess a terminator mustang. 4.6 DOCH S/C cobra motor.
Old Aug 13, 2010 | 05:56 PM
Hawkins04's Avatar
thats what i was thinking too^^
Old Aug 13, 2010 | 06:23 PM
AlabamaGuy's Avatar
Why not just buy a cobra?
