need help with an 06 Grand Prix
Also, have you changed the fuel filter? I had a car that would fall right off the power band because of a mostly-plugged fuel filter. That didn't throw a code, either.
And if these things dont' cure it, it wouldn't hurt to change them anyway if they're the original parts.
The message here is to start with the simplest, most obvious answer.
1. Air
2. Fuel
3. Spark
The first one is easy...You're still breathing and the car still runs, so you know it's getting air. Is the air filter clean? Anything obstrucing the intake? That's really about all I can think of for that.
Fuel is a bit more difficult. As I mentioned before, has the fuel filter been changed? It could be plugged. The fuel pump could be on the way out, too. Maybe you could buy or borrow a a fuel pressure gauge and see if you get adequate pressure under boost. It's also possible, though unlikely, that it may be an injector problem. That would be the last thing that I would check, if everything else is okay.
For Spark, it's pretty basic. How are the plugs? Did you pull any to read them? That can give you insight into the two things above. Are they black and sooty or are they whitish and/or pitted? The clues are there. How are the ignition wires? Have they been changed? Did you check them for resistance with a meter? Lastly, are you on the original coil pack? My Grand National, at one point, was way down on power. I traced it to the ancient factory coil pack that had trouble carrying load around 4000 RPMs or more. I would find out what the specs are for your coil pack and check it with a meter. Also, it would be advisable to check the ground wires for the engine, as a bad ground can have an impact, too.
Lastly, you may want to check the function of the boost solenoid and bypass-valve. These would obviously have an impact on the way power is created in your motor.
As I said before, check the BASIC stuff before you get into the exotic things (torque management, etc.) mentioned earlier. Even if none of the specific things I mentioned are the cause, troubleshooting using the parameters I described will most likely lead you to the root cause.
