Crazy Warning Lights
Old Aug 18, 2010 | 07:25 PM
plmrass's Avatar
Default Crazy Warning Lights
Hi guys I got in my car today and took a half hour ride by my parents house and the house went haywire. LOL I got in the traction control light went on sayin it was bad or some sort. Ignored it kept driving later it went on again said traction control, stability control, brakes, abs. Then went on again later saying traction brakes and abs. It wasnt exactly the same messages every time. So I dont know if it appears I have multiple problems or if somehow all or some of these are related through same sensors. But somehow when these started popping up while I was driving when they did pop up the radio went off when they went to pop up so I dont know wtf is going on. I just got home so didnt have a chance to look at anything yet. Any adivice would be appreciated though. Thanks Jeff
Old Aug 18, 2010 | 07:31 PM
jdwilks's Avatar
Think I made sense of all that but my first thought is you have a wheel sensor shorting out. Possible loose connection or frayed wire on one of your sensors which are located in the wheel hub
Old Aug 18, 2010 | 07:40 PM
JP_GXP's Avatar
Check battery connection first, happened to me, negative was loose. Then check speed sensor. If those two are good TCM may be going out. Had experience with all 3.
Old Aug 18, 2010 | 08:12 PM
LS4_DeltaV's Avatar
Yes,
Checking the battery grounds is important. Battery to cable and cable to frame.
Do you have something to read the DTC's that have been set?
If so see if P0106 P0107 or P0108 is set
Cheers
Last edited by LS4_DeltaV; Aug 18, 2010 at 08:16 PM. Reason: I never said i could spell
Old Aug 18, 2010 | 09:22 PM
2005gxp's Avatar
scan it and report back to us
Old Aug 18, 2010 | 09:51 PM
plmrass's Avatar
Well its no codes technically its the tcs lights on and the other **** flashes on the dic and just erases. Why would the brake light flash on the dic does it flash if the front brake pads are low or??? So theres no lights on so no codes to be pulled unfortunately It might just have to go up on jacks. Thanks Jeff
Old Aug 19, 2010 | 07:03 AM
Kazmaniac's Avatar
Like the guys said - check the battery and connections. Had that with the stock battery, didn't happen again w/ the Optima RT.
Old Aug 19, 2010 | 05:34 PM
LS1 Racing's Avatar
Battery. Or connections to the battery.
