Oscillating Noise Coming from Right Rear
So a couple weeks ago I decided to do something about it. After consulting several car guys including my dad who's worked on cars just about his whole life, everyone was convinced it was the hub bearing--so I replaced it on that side. Noise is still there.
So, my question to anyone who has experience with this, or anyone who wants to make an educated guess, is twofold:
1. Is the hub the problem?
2. Did I possibly change the wrong side? (It definitely sounds like it is coming from the right-rear--passengers in the car agree)
Thank you for any help you can give!
EDIT: It's not the tires...I got four new tires after the sound started because I needed them, but it did not solve the problem.
I'm thinking it could possibly be a warped rotor...can drilled rotors be machined?
Even though the chances are slim, it is possible you changed the wrong side. I run a used car dealership that also has service. We have changed hundreds of wheel bearings and we have seen a few vehicles come in with the typical wheel bearing "hum" coming from the left rear side (or whatever side). We change the left rear hub and sure enough, the noise was still there
It confused the hell out of us lol. So, we changed the other side and the noise was gone. This does not happen often, but we have experienced it. Now we make sure to test each side before we make a final diagnosis. It's also possible that both hubs are bad. Hope this helps, let us know what you find.
Also, how do I "test" a hub?
Road testing for which side- While driving your car on a straightaway, slightly turn the wheel left. But not enough to yank the car off the road lol. Listen for a change in sound. Does the hum get worse? Does the hum get quieter? Try this at various speeds to make sure you're hearing the same thing. If it gets louder while turning the wheel left, the right side is the bad side. Repeat this for the other side. You also need to listen if it's coming from the front or rear. Having a second set of ears is always helpful, so grab a friend for the ride.
Lift testing for front hubs only- Put the car on a lift (one where the wheels can spin freely) and have someone put it in drive. Slowly accelerate up to the MPH where the sound is the loudest. Have someone listen to each front wheel. You kind of need a trained ear for this, but listen for differences in noise levels for each of the front wheels. Is one side louder than the other? If yes, then the louder wheel has the bad hub. If they are both bad, this might be a little harder to confirm. But a good hub should spin pretty quietly with minimal "hum."
These aren't exactly "fool proof" methods but they seem to do the trick.
Turning from left to right isn't the best way because you still have all four tires making contact and you're changing the angle of each one slightly which will sound different but isn't a sure fire diagnostic.
kl_327 were you ever able to fix the humming?
Thanks in advance for the help!!
