"bog" under acceleration
Thank God its under warranty for another 2 1/2 years and 30k some odd miles.
I've got 51K on mine.
After reinstall, start engine and allow it to idle (no load) 1 min. Then turn on all power acc, and apply brake, put in gear and sit for 2 min., return to park and return loads to normal. Then drive as you wish.
and, get a tune...
helps with throttle response, acceleration, pull, etc etc...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Lew, I am planning on getting a tune, as soon as I replace the front wheel bearing (scheduled next Monday) then when the tranny finally dies and I install a TEP tranny... I don't want to rush the death of my original tranny though..
AG, my rpms flutter as well when cruising, every once in a while the tach will jump a couple of hundred RPM and then settle down, once the converter locks up it will hold steady
DO NOT USE THROTTLE BODY CLEANER ON THE MAF.
(IT HAS SPECIAL SENSORS IN ITand DO NOT REMOVE THE SCREEN)
As for your rpm flutter... Wait until you have cleaned as recommended and put 50-100 miles on it then report back if the flutter/rpm hunt is still there.
and I don't drive like grandma either!!! my car regularly sees 100 mph, spirited launches from lights, kick it down from 60mph on the highway to "pass" people...
as for the MAF sensor cleaner, this is what you need:
http://www.crcindustries.com/auto/co...x?S=Y&PN=05110
I get it at my local autozone...
Lew, I am pretty sure the tranny is on its way out, so I am not planning any mods as of yet
By the way, correctly clocking the MAF is just as important as cleaning it. Because the LS4 has a bend shortly after the MAF and because the sensing elements are on only one side of the divider, the MAF is really sensitive to being rotated. I've chased my own tail with that one, to the tune of +/-5% or so for relatively small changes. Your fuel trims will save you from any real trouble, but it can force you stupid rich at WOT.
