Code on GXP
Old Nov 29, 2010 | 04:30 PM
RedArmy87's Avatar
Default Code on GXP
I was driving my car home this past weekend after going to the the Grey Cup and on my way home after about 400km of driving my engine light came on when I got home and coded it i got P0326 Knock sensor 1 circuit (bank1) any help on whats caused this or how to fix it would be much appreciated
Old Nov 29, 2010 | 04:43 PM
LS1 Racing's Avatar
That's a pretty uncommon code, but I imagine it means that the knock snesor either is not responding or out of spec.
Do you have any means of monitoring knock retard while driving? If you do, then I would clear the code and drive it and see if you're getting any KR. I wouldn't drive it hard, though, just in case. If you have the stock tune, then you should be seeing frequent KR in the 3-6 degree range. It varies with temp, fuel quality, and altitude, though. But if you're seeing very little knock retard or none at all (assuming the factory tune is installed), then it's quite possible you have to replace a knock sensor.
For the record, I've never seen a knock sensor fail, but it's worthwhile to troubleshoot the problem, rather than just replace the sensor, which is mounted to the valley cover UNDER the intake manifold.
Old Nov 29, 2010 | 05:00 PM
RedArmy87's Avatar
I put my factory tune back on for now(before i only had the diablo 91 with dod), I have no way of measuring knock
Old Nov 29, 2010 | 05:35 PM
Ill_Born_ss's Avatar
"I have no way of measuring knock" You CERTAINLY DO!
If you have a predator/trinity, it can log it for you or you can select it and watch it real time...
I think you just got a tank full of swamp water somewhere. Put two little containers of gasline antifreeze and fill it with some good 91 or better and enjoy!
Old Nov 29, 2010 | 05:41 PM
RedArmy87's Avatar
I thought you need the data cable to log and watch real time with the predator I'll defiantly look in to to it tomorrow as for gas I only run 94 in it pretty sure its not the gas
Old Nov 29, 2010 | 05:49 PM
LS1 Racing's Avatar
You can view real-time with a Predator and no data cable. You only need the cable to export the log file to a PC.
Let us know how it goes.
Old Nov 29, 2010 | 06:01 PM
You can also see the sp gravity of the fuel on board with the predator and the actual knock sensor.
Also just incase you are unaware.. in Canada the highest octaneis 91 everything above that is achieved over that is done with ethanol, you may have gotten to much, more than 10%
