Center Consol
Old Jan 1, 2011 | 01:39 PM
2005gxp's Avatar
Default Center Consol
How does the center consol come out? ive got the 2 10mm bolts on the side's and the 4 t10(i think) bolts in the armrest storage botttom but its still stuck on something at the back, can anyone give me some insight? thanks
Old Jan 1, 2011 | 02:03 PM
GXP25's Avatar
Four 10 mm bolts on the sides and that's it. Two up front and two towards the rear.
Go under the console towards the front (behind/under the radio) and unclip the connectors. From there, you'll want to lift.
The console is kept in place by a clip that pops into the shifter and two more under the armrest. Just push/pull straight up. Beware because you can break some plastic:
Clips stuck under the armrest:
Those two clips should be attached to the console plastic.
Center console clips into the shifter as well. Broken due to pulling towards the rear and not lifting:
Glued with super glue (ineffective). I used J-B weld to fix it later on:
What the car looks like with no console:
Test fitting to see if the driver seat track will fit in the passenger seat area (it does):
Old Jan 1, 2011 | 04:23 PM
2005gxp's Avatar
ok, so i just need tp pull harder lol and i got all 4 out just forgot how many i removed, did it 2 weeks ago lol
very helpfull thanks alot.
