Reset tpms
Old Jan 15, 2011 | 08:36 PM
havelegs's Avatar
Default Reset tpms
Anyone know how to reset the tire pressure monitoring system? I had my tires rotated and now they don't show the correct locations.
Old Jan 15, 2011 | 08:43 PM
hazards280's Avatar
On the GXP you just do it on the DIC, but I have no clue on Impala's, Sorry
Old Jan 15, 2011 | 08:48 PM
evil 5.3's Avatar
it in the owners manual you have to hit the reset in the dash menu the as the light comes on like the left turn signal you let air out till the horn honks and move around the car it will honk twice when your done
Old Jan 15, 2011 | 08:51 PM
havelegs's Avatar
About how much air do you have to let out?
Old Jan 15, 2011 | 08:52 PM
jim ravencraft's Avatar
Hi,
turn switch to on not started....press 'i" scan until you get tpms on panel--
press check and hold a couple of seconds. This should do it.......the aforementioned are located to right of steering wheel....check tire pressures and have a blessed day.........jim
Old Jan 15, 2011 | 09:40 PM
GXP25's Avatar
What you want is a relearn since you essentially moved the sensor positions.
If you had your tires rotated at a shop, they really should have done this for you.
You have a 2005 which means you don't have the sensors. That will simply reset the computer which determines tire pressure based upon tire/wheel rotation.
2004-2006 Grand Prix:
2007-2008 Grand Prix:
Originally Posted by jim ravencraft
Hi,
It's a little bit more involved than that.
You're on the money. I'll clean it up a little in the next few posts.
Old Jan 15, 2011 | 09:41 PM
GXP25's Avatar
2007 Grand Prix:
TPM Learn Procedure
Important: Before proceeding, ensure that no other learn procedure is being performed simultaneously or that tire pressures are not being adjusted on another TPM equipped vehicle within close proximity. Stray signals from other TPM equipped vehicles just driving by can be inadvertently learned. If any random horn chirps are heard from the vehicle while performing the learn procedure, most likely a stray sensor has been learned and the procedure will need to be cancelled and repeated. Under these circumstances, performing the TPM Learn Procedure away from other vehicles would be highly recommended. In the event a particular sensor activation does not cause the horn to chirp, it may be necessary to rotate the wheel valve stem to a different position due to the sensor signal is being blocked by another component.
  1. Place the ignition switch in the proper position as follows:
    • With standard ignition switch, place the switch in the RUN position.
    • With electronic keyless ignition, place the switch in the ACCY position.
  2. Initiate the TPM Learn Mode using one of the following procedures:
    • Using a scan tool, initiate the TPM Learn Mode. A double horn chirp will sound indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    • On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    • On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the RELEARN TIRE POSITIONS message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds and the DIC displays a TIRE LEARNING ACTIVE message indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  3. Starting with the left front tire, learn the tire pressure using one of the following methods:
    • Hold the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the activate button and wait for a horn chirp. Once the horn chirp has sounded, the turn signal in the next location to be learned will illuminate.
    Caution: Over inflating tires may cause personal injury or damage to the tires and wheels. When increasing tire pressure do not exceed the maximum inflation pressure as noted on the tire sidewall.
    • Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the turn signal in the next location to be learned will illuminate.
  4. After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 3 for the remaining 3 sensors in the following order:
    4.1. Right front
    4.2. Right rear
    4.3. Left rear
  5. After the LR sensor has been learned, a double horn chirp will sound indicating all sensors have been learned.
  6. Turn OFF the ignition to exit the learn mode.
  7. After the learn mode has been exited, adjust all tires to the recommended pressures. Refer to Vehicle Certification, Tire Placard, Anti-Theft, and Service Parts ID Label .
2008 Grand Prix:
TPM Learn Procedure
Important: If using the scan tool to enable the learn mode, the J-46079 must be used to activate the sensors. When this preferred method is used, any stray sensor signals will not affect the learn procedure. In the event a particular sensor's information is displayed on the special tool upon activation but the horn does not chirp, it may be necessary to rotate the wheel valve stem to a different position due to the sensor signal is being blocked by another component.
If using the keyless entry transmitter to enable the learn mode, the J-46079 or Pressure Increase/Decrease Method may be used. Before proceeding with this method, ensure that no other learn procedure is being performed simultaneously or that tire pressures are not being adjusted on another TPM equipped vehicle within close proximity. Stray signals from other TPM equipped vehicles just driving by can be inadvertantly learned. If any random horn chirps are heard from the vehicle while performing the learn procedure, most likely a stray sensor has been learned and the procedure will need to be cancelled and repeated. Under these circumstances, performing the TPM Learn Procedure away from other vehicles would be highly recommended. In the event a particular sensor activation does not cause the horn to chirp, it may be necessary to rotate the wheel valve stem to a different position due to the sensor signal is being blocked by another component.
Preferred Scan Tool Learn Enable Method
  1. Using a scan tool, initiate the TPM Learn Mode. A double horn chirp will sound indicating the Learn Mode has been enabled.
  2. Starting with the left front tire, active the sensor by holding the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the Activate button and wait for a horn chirp. Once the horn chirp has sounded, the sensor information is learned.
  3. After the horn chirp has sounded, repeat step 2 for the remaining 3 sensors in the following order:
    • Right front
    • Right rear
    • Left rear
  4. When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
  5. Ignition OFF, adjust all tires to the recommended pressures. Refer to Vehicle Certification, Tire Placard, Anti-Theft, and Service Parts ID Label .
Alternate Keyless Entry Transmitter Learn Enable Method
  1. Ignition ON, initiate the TPM Learn Mode by simultaneously pressing the keyless entry transmitter lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled.
  2. Starting with the left front tire, learn the tire pressure using one of the following methods:
    • Right front
    • Right rear
    • Left rear
  4. When the left rear sensor has been learned and the double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
Old Jan 15, 2011 | 09:42 PM
GXP25's Avatar
2008 Impala:
TPM Learn Procedure
If using the keyless entry transmitter or DIC buttons to enable the learn mode, the J-46079 or Pressure Increase/Decrease Method may be used. Before proceeding with this method, ensure that no other learn procedure is being performed simultaneously or that tire pressures are not being adjusted on another TPM equipped vehicle within close proximity. Stray signals from other TPM equipped vehicles just driving by can be inadvertently learned. If any random horn chirps are heard from the vehicle while performing the learn procedure, most likely a stray sensor has been learned and the procedure will need to be cancelled and repeated. Under these circumstances, performing the TPM Learn Procedure away from other vehicles would be highly recommended. In the event a particular sensor activation does not cause the horn to chirp, it may be necessary to rotate the wheel valve stem to a different position due to the sensor signal is being blocked by another component.
  1. Using a scan tool, initiate the TPM Learn Mode. A double horn chirp will sound indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
  2. Starting with the left front tire, active the sensor by holding the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the Activate button and wait for a horn chirp. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
  3. After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
    3.1. Right front
    3.2. Right rear
    3.3. Left rear
  5. Ignition OFF, adjust all tires to the recommended pressures. Refer to Vehicle Certification, Tire Placard, Anti-Theft, and Service Parts ID Label.
Alternate Keyless Entry Transmitter or DIC Learn Enable Method
  1. Ignition ON, initiate the TPM Learn Mode using one of the following procedures:
    • On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the TIRE LEARN message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
    • Hold the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the activate button and wait for a horn chirp. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    • Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
    3.1. Right front
    3.2. Right rear
    3.3. Left rear
Old Jan 16, 2011 | 01:32 PM
havelegs's Avatar
Wow great info thanks guys! I will print and bring this to the tire place since they said they couldn't do it. I could do it but I don't have a way to fill them back up with air!
Old Mar 23, 2012 | 09:02 PM
natedra's Avatar
Default date and time wont auto set on 2007 pontiac. check engine light is on.
Screen doesn't say anything wrong with engine.
Old Mar 24, 2012 | 10:16 PM
ghetto joe's Avatar
wow if they dont know how to reset a GM TPMS by now i would be scared to let them take apart any tire with a sensor they may damage the sensor not knowing how to be careful, heck they may not even know you are not supposed to use any old stem core or cap on sensor too.
