holy spark plugs batman!
Old Mar 19, 2011 | 03:38 PM
DavidGXP's Avatar
2012.. Lol
Old Apr 16, 2011 | 10:26 PM
nat120's Avatar
I checked my front four spark plugs. I have a 2006 Monte Carlo SS. The plug all the way to the right had a lot of oil on the threads but the rest of the plug looked pretty good. The other front three looked good and no oil on the threads. Is it bad to have oil on the thread of the plug in the front all the way to the right?
Old Apr 17, 2011 | 08:48 AM
JC05GXP's Avatar
Seems to be normal with this engine. I just changed mine and the number 1 and 7 in from were full of gunk and oil on the threads.
Old Apr 18, 2011 | 08:12 AM
rvd9431's Avatar
try rockauto.com for cheap plugs
Old Aug 14, 2012 | 11:55 PM
Tomkat3012's Avatar
BlauGXP thanx for that link their prices are 50 percent cheaper then most places
Old Aug 15, 2012 | 02:04 AM
SleeperGXP's Avatar
I bought my gxp 5 months ago has 153,000 miles and I have a misfire idk when the plugs and wires were last changed but my cars tore apart already for the tranny rebuild will I be ok just replacing plugs or should I replace wires to and is there anyway to know for sure?
Old Aug 15, 2012 | 09:33 AM
The_Madcat's Avatar
With that mileage, do the wires too. There is a good chance that one or more of the wires could be damaged when removing them to change the plugs. They are due anyway, might as well do them now when it is easy.
Old Aug 15, 2012 | 11:37 AM
SleeperGXP's Avatar
There so damn expensive though even for the front ones that are two inches long it's bullshit
Old Aug 15, 2012 | 12:30 PM
SleeperGXP's Avatar
What wires do you reccomend guys?
Old Aug 15, 2012 | 01:06 PM
The_Madcat's Avatar
You can get the cheaper wires from Autozone or wherever but they will most likely cause KR. Get the good ones, you only have to do it once every 100k or so.
Old Aug 15, 2012 | 02:46 PM
gixper's Avatar
Do you have to change the rear plugs from underneath the car or can you reach them from the top? Never tuned up a car witha transverse motor. Either way it looks like it's gonna be a PITA.
Old Aug 15, 2012 | 02:50 PM
  #32
blkchevyz's Avatar
when i was pricing it out awhile ago rockauto.com was probably the cheapest. but you dont get to many options for plugs.
Old Aug 15, 2012 | 06:14 PM
  #33
straitchev's Avatar
If youve changed plugs on a fwd before, this is 1-2h job max. Rocking the engine forward similar to 3.4 and 3.8 motors works with the fwd 5.3. It only gives 1-2 inches on the back but your knuckles will thank you. While your back there doing rear plugs, you might as well replace the 02 sensor if it needs it
Old Aug 15, 2012 | 08:30 PM
  #34
The_Madcat's Avatar
Easiest way I found to change the back row was to remove the coils/bracket. Easy peasy then.
Old Aug 15, 2012 | 09:28 PM
  #35
91parkave's Avatar
Moderator
slightly but thats because of the wires being a bitch in the back to pull but its easy. remove the coil bracket 4-5 10mm bolts unclip your 02 and coil pack from the main harness and remove then you have a straight shot at your plugs...BTW go to summitracing.com to get your wires MSD's have great reviews
THIS^^^
Old Aug 17, 2012 | 09:03 PM
  #36
gixper's Avatar
Just changed my plugs...you were absolutely right. Took me about an hour. Nothing to it...so glad I didn't try to tilt the motor! So not necessary.
Changing transmission fluid/filter in the morning
Old Aug 17, 2012 | 09:08 PM
  #37
gixper's Avatar
Any plug experts here? These are my old ones. What does the condition of these tell me about my engine?
Attached Thumbnails holy spark plugs batman!-101_1705.jpg   holy spark plugs batman!-101_1703.jpg
Old Aug 17, 2012 | 09:27 PM
  #38
baltsk8er69's Avatar
By looking at the picture....it looks like your engine is missing 8 plugs. Sorry I had too.
Old Aug 17, 2012 | 09:39 PM
  #39
gixper's Avatar
Please don't quit your day job!
Old Jun 7, 2013 | 09:47 AM
  #40
stok2shok's Avatar
Default Grand Prix GXP Plug Question
2008 Grand Prix GXP
Magna Flow Exhaust
CAI
All Other Equipment is stock
My question: If I intend to do a 3" downpipe, Transcooler, and potentially Thorley Headers, is there any harm with installing the NGK Iridium TR6IX right now? Will these plugs run ok with an almost stock setup?
I called Promax Performance, and the gentleman that answered stated that they generally run as cold a plug as possible when racing. The trade off with the LS4 is going to be either run a colder plug (TR6IX) and have more power, but less plug life, or go with factory recommendation (41-985) and have less power, but more life.
Hmmmm. Decisions, decisions.
Thanks.
stok2shok
