zzp shift kit question
Old Apr 14, 2011 | 10:52 PM
vroom_vroom's Avatar
Default zzp shift kit question
so im ordering a couple shift kits from zzp ( multiple gxps) and it states that it has four different firmness levels what did you go with i want some thing that will "thump" into gear without destroying my drive line components
Old Apr 15, 2011 | 08:10 AM
Brian396's Avatar
You might want to order just one. They just use spacers. You may be able to make your own, once you see how they do it. For that matter I have a ZZP kit out in the garage that I would sell for $15 shipped, minis the gasket and filter.
Old Apr 15, 2011 | 09:46 AM
LS1 Racing's Avatar
I wouldn't buy anything from ZZP for any LS4 car, mostly on principle. They assume that, what's good for an L67 is fine for an LS4.
Quote from ZZP: "We don't recommend a trans cooler because they leak..." Yeah, whatever dude.
Old Apr 16, 2011 | 02:11 AM
who are u guys using for the kits? i know intense has a horrible rep
i got do something caus my trans was killing me at the track tonight it cost me at least a half second on my runs the best i pulled off was a 14.8@ 93mph i know we are at 2000 ft above sea level but man that was embarrassing
Old Apr 16, 2011 | 08:24 AM
JC05GXP's Avatar
I think just about everyone is using the transgo shift kit. I just got mine and will be installing soon.
Old Apr 16, 2011 | 10:08 AM
LS1 Racing's Avatar
X2 on the TransGo.
Love mine!
Old Apr 16, 2011 | 12:45 PM
you guys just using the one for the 4t65e they dont show one for the hd
Old Apr 16, 2011 | 12:55 PM
JC05GXP's Avatar
Yeah, those parts are the same
Old Apr 16, 2011 | 01:58 PM
LS1 Racing's Avatar
Yup, same kit.
Old Apr 16, 2011 | 02:14 PM
So next question when my cat disappears will it effect drivability? My tuner is a ways a way so it would have to be driven there
Old Apr 16, 2011 | 02:21 PM
LS1 Racing's Avatar
Shouldn't hurt drivability, though it will lean you out quite a bit. You'll also be looking at the CEL a lot until you get it tuned.
Also, make sure your tuner deactivates the cat over-temp routine in the ECM. That will really help out your highway mileage.
Old Apr 16, 2011 | 06:56 PM
im just trying to figure out if it will still show up in the ecm around inspection time..............
Old Apr 16, 2011 | 07:04 PM
JC05GXP's Avatar
If you dont get it tuned out it will throw a CEL. Once tuned out no issues with emissions.
Haulin_Ls4_GxP's Avatar
If they hook somthing up to the obd2 port and look at suff like a tech at a shop wpuld than yes they would see yhe rear o2 showing no activity.
Old Apr 17, 2011 | 04:27 PM
Sadden's Avatar
Love my Transgo , the zzp kits are garbage 3800 guys report they can barely feel them.
Cats are garbage , pull that pos off.
Just make sure you get the appropriate codes removed etc , i believe COT was allready mentioned.
Old Apr 17, 2011 | 06:02 PM
yea if i ditch the cat i have to find a way around the smog other than bribery
but my question of the day is can you get a lower od gear for the trans im anticipating complete failure is unfortunately right around the corner after this weeks trip to the drag strip dont want to put the money in it but if i have to...........
Old Apr 17, 2011 | 06:13 PM
LS1 Racing's Avatar
Just put the catted pipe back on the car at smog time.
Also, I'm pretty sure there's only one OD ratio for a 4T65. Why change it, anyway? A lower gear means worse mileage with pretty much no benefit. If you mean lower numerically, our .70 is pretty close to the ideal for an OD gear in 4-speed automatic. If you went to a lower numerical ratio (.50, etc.) and assuming one is available, you'll wind up spending less time in OD or you'll lug the engine.
Old Apr 17, 2011 | 06:22 PM
numerically would be correct the whole 85 on the free way is a ***** on gas
it looks like if i mess with the cat thats the route i will have to go just cant figure out how much $$$ i want to put in to a car i dont plan on keeping more that a year and a half but i guess if my tranny dies what the hell why you have your wallet out you might as well get it over with but no cat and a new tune would get me down to a low 14, man thats depressing
Old Apr 17, 2011 | 06:45 PM
LS1 Racing's Avatar
I guess it depends on how much time you spend at 85 MPH on the highway versus other driving. Remember, the lower (numerically) the OD ratio, the less time you spend in the gear. My '99 Camaro SS had a 3.42 rear and I could really only use 6th at 70 MPH or above. 6th gear in that car was .50. I would get my best mileage in 5th (.74) and about 65 MPH. Any faster, even in 6th, and the mileage would still drop.
Old Apr 17, 2011 | 08:31 PM
is there room on the down pipe to drop in a cut out before the cat
