EVAP system
Old Apr 23, 2011 | 11:34 PM
JiggyGXP's Avatar
Default EVAP system
HAs anyone had this problem with the evap system code says large leak can someone help me trouble shot this?
Old Apr 24, 2011 | 01:00 AM
MikeyGXP's Avatar
I'm having the same issue right now. Hope to have it in this week for a diagnosis. My ODB scanner says P0455 (Large EVAP leak). I'll let you know what my results are.
Old Apr 24, 2011 | 06:18 AM
Haulin_Ls4_GxP's Avatar
Bad purge valve
Old Apr 24, 2011 | 07:00 AM
Kazmaniac's Avatar
Welcome guys!
There is a $30 valve located near the fuel filler. One screw and a vacuum line IIRC. As easy to change out as an oil filter.
Search the code in this forum to get the details.
Old Apr 24, 2011 | 03:42 PM
JiggyGXP's Avatar
So is that why I hear air being push out from somewhere when I cut the car off? And this valve is located up front?
Old Apr 24, 2011 | 07:02 PM
JiggyGXP's Avatar
Thanks guys for the help next tune up
Old Apr 27, 2011 | 11:18 AM
MonteSS8707's Avatar
Got a code for the purge valve right now myself. Gna change it when I get around to it
