- Camaro and Firebird: How to Check Tire Pressure
Step by step instructions for do-it-yourself repairs
Browse all: Tire Repair and Maintenance
tire pressure
I also run at least 2 more psi than the door sticker. but that puts me at 32psi for my TPMS and most gauges are reading like 36psi...
Every tire is different so once tire at 40 will be great, your next set wont handle for crap at 40 or 30 but like to be at 34.. So yes the door jam sticker is a starting point... but we are on here to modify our cars.. what easier than tire air preasure.
I like having extra couple psi in my tires because i never know when ill be caring extra weight and slight improvement in gas milage.
And as for airing down street tires. I have been trying different psi at the track.. i find a few psi lost has worked for me so far...even with our short side walls it seems to still allow a bit for contact patch and sidewall flex. though still experimenting... Then again when i air down its generally from a higher preasure to begin with
Did you read the Popular Mechanics link I posted? They drove damn near 400 miles with factory PSI and the same route back with 13 PSI more in each tire. The difference was .05 better mpg with the tires having 13 PSI more. Seeing as no trip is identical no matter if it's the same route or not, there is no difference in mileage. Handling, braking distance and acceleration times are all worse when tires are over inflated as well.
I'm not talking about the guys that run tire PSI close to the recommended PSI, I'm referring to the people that believe the more pressure the better.
Lets try to keep this forum as factual as possible
