service stabilitrack / service traction control
Old Jul 15, 2011 | 06:54 AM
redeemedtat2's Avatar
Default service stabilitrack / service traction control
every once in a while i get a service stabilitrack / service traction control message on the dash when i go wot and the car makes it's shift from 2 to 3. the shift is not harsh by any means and i almost always turn off the traction control off the moment i start the car.
anyone else experience this? is it something to be concerned with?
Old Jul 18, 2011 | 04:33 AM
Panther427's Avatar
I cant remeber anyone talking specificly about a problem like that.. There are a slew of items that can cause that message to apear. Maybe a loose or damage ABS sensor or wire
Old Jul 18, 2011 | 10:45 AM
redlightrampage's Avatar
Had similar problems, there is a TSB out there for ABS sensor issues. Mine was serviced under warranty they ended up replacing the entire axle because they couldn't get the hub off.
