Intake Manifold Help
Old Jul 19, 2011 | 12:00 PM
06silverss's Avatar
Default Intake Manifold Help
I just recently got a LS4 ported intake manifold and ported throttle body. The wonderful USPS didn't take care of it and now it has small styrofoam pieces inside of it and I was wondering the best way to get them all out?
Also I was wondering if the copper hose pipe on the throttle body was suppose to be plugged or is it suppose to flow? Damn USPS! Thanks
Attached Thumbnails Intake Manifold Help-rsz_dsc03048.jpg   Intake Manifold Help-rsz_dsc03047.jpg   Intake Manifold Help-rsz_dsc03057.jpg
Old Jul 19, 2011 | 01:15 PM
gxp-miller-gxp's Avatar
copper house pipe?? the part that the vacum line or whatever connects to the wraps around and connects to the top of the intake?? if thats it then it should be in lol
Old Jul 19, 2011 | 01:16 PM
hmm you should post pics so we can see
the styrofoam is no big, just use air to blow it out,just shake it for a while
Old Jul 19, 2011 | 01:20 PM
06silverss's Avatar
The copper hose fitting. So it should flow through?
Old Jul 19, 2011 | 01:23 PM
Ls2SilverBullet's Avatar
Is the copper pipe on the bottom of the tb I would sayy it is a coolant line. If its anywhere else its probably a vac line. If its a vac line you can probably see a port on the inside of the TB that would flow to it. If its a coolant line there will be an in and an out for the coolant to flow through. Or you could run a bypass.
As for the **** in your intake, I would use air. If that dosnt get it out take off ur tb and use water and let it dry out well
Old Jul 20, 2011 | 11:52 AM
06silverss's Avatar
Pics Added
Old Jul 20, 2011 | 03:05 PM
xxtheshockerxx's Avatar
****** USPS. They find a way to **** everything up
Old Jul 20, 2011 | 05:33 PM
smokin06impala ss's Avatar
Here is a pic of what goes on the vacumn line that goes on the side of the TB .
Btw lesson learned on shipping with USPS
Old Jul 20, 2011 | 08:03 PM
1CL3ANSUP3RSPORT's Avatar
I always use USPS,but word to the wise packit your self
Old Jul 20, 2011 | 08:17 PM
I did but they sent it back when it was in Dallas Tx to the local Inspector's office for suspious activity.They claim they didnt open box but at the look of those pics I doubt they didnt. First and last time I deal with them !!!
Old Jul 21, 2011 | 10:29 AM
06silverss's Avatar
Thanks for the pic and all the help! So it is not suppose to plugged. Thanks
Old Jul 21, 2011 | 11:05 AM
Correct !!!
Old Jul 21, 2011 | 11:42 AM
That what's suck,cause some flat rate boxes are not big enough. I sent out my engine cover, exhaust manifolds,down pipes,stereo equipment, etc. Not once have I heard a complaint about packaging ,non were flare rate except amps,HU,speakers...
