Removing Serpentine Belt
Searching through some old threads on here, "Supercatxr7" says the following:
"Take off wheel and plastic panel that covers harmonic balancer and such. You will see the spring for the tensioner. Use a pry bar and push down on the top of the spring area and pull off the belt."
He has an 11 second MC SS, so it appears he knows his way around these motors pretty well. However, the method he mentions seems like a good way to also break something to me. Is he prying up on the inner fender sheet metal wall, and pushing down directly on top of the spring? Kind of vague in the description there. I even read of a guy trying this, and having close to an additional $200 in repairs because of the shortcut.
What is the common knowledge nowadays for removing this belt, other than buying the tool? Is his shortcut the simplest method, or is there another combination of tools that can do it? I tried every combination of tools I have, and nothing would reach the 1/2" hole well enough for me to put some oomph on it. If I need to just buy the tool, I'll buy it.
Thank you in advance for your input!
Reverse for install.
