Wheel experts, need some help with fitament
Old Aug 3, 2011 | 10:47 PM
supercatxr7's Avatar
Default Wheel experts, need some help with fitament
Looking for a lightweight drag wheel for the Monte Carlo and my Hoosier QTP 26 x 9.5 x 16 drag tires. Hoosier recommends a 6" to 8" wheel.
I found the following Moda M10 wheel which is in our bolt pattern and a few pounds lighter than most wheels. Anyone see any fitament issues on the car with the Hoosiers and the wheel below? I have 16x8 mustang rims on it now with same Hoosier tires.
MODA MD10
Offset: 42mm
Backspacing: 5.94"
Bolt Pattern: 5-115
Rec. Tire Size:225/60-16
Weight: 17.3lbs.
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
Old Aug 3, 2011 | 11:29 PM
AlabamaGuy's Avatar
MODA MD10
Offset: 42mm
Backspacing: 5.94"
Bolt Pattern: 5-115
Weight: 17.3lbs.
What's the width on that wheel? Should be 8" with that offset.
Old Aug 3, 2011 | 11:31 PM
16 x 7.5
Old Aug 3, 2011 | 11:36 PM
AlabamaGuy's Avatar
They will stick out 15mm further than stock and give you 3mm more clearance on the inside
Old Aug 3, 2011 | 11:44 PM
Thanks! Is there a website I can plug the wheel info into and get the info that you provided for some other wheel options I'm looking at?
Old Aug 4, 2011 | 12:03 AM
AlabamaGuy's Avatar
Here you go, sir.
http://kgm.tiwing.com/calcs/offsetcalc.htm
Old Aug 4, 2011 | 12:50 AM
Thanks
