Car starting problems
Old Aug 29, 2011 | 09:37 AM
Vectus's Avatar
Default Car starting problems
It's not the battery, had it checked its fine. Connections are a bit dirty, cleaning then up today, but im thinking the starter is the issue. It clicks a couple times like when the battery is dying. and then starts. Or won't start, i return the key and it'll sometimes start just fine or click then start. So, my question is, does it sound like it's the starter?
Old Aug 29, 2011 | 11:27 AM
LS1 Racing's Avatar
You're on the right track in cleaning the terminals first. I recommend a can of Coke, a small cup and a brush. It takes the corrosion right off. Then you can drink what you don't use.
If that doesn't cure the problem, then you're looking at either the starter or the solenoid.
Old Aug 30, 2011 | 04:44 PM
Vectus's Avatar
Well just finished cleaning it, doesnt look like thats going to be the problem. Probably going to be taking it to the dealer to argue with them that the intake isnt the issue.
