Camber Bolts Question
Negative Camber helps the car corner better, but the combination of the negative camber and the large amount of toe in that these cars run causes the inside of the tires to scrub and wear prematurely.
The dealer wants to slot the struts so that they can gain more adjustment but I am going to try the bolts first, they are cheaper and I already have them.
I'm not stock, so that's I'm running them on all fours.
As for the alignment, the shop would have to install them before performing the alignment. The proper alignment would be achieved with the bolts in place.
1- There is no adjustment from the factory, sorry. Meaning they don't wanna **** with it.
2- They are goin to have to removed the strut from the car to notch it. Meaning if you want us to do it, were gonna stick it in your *** on labor.
Again, all IMO
