Throttle Body
Old Sep 12, 2011 | 05:03 PM
Sittingmongoose's Avatar
Default Throttle Body
I know this was discussed a few years ago but has anyone replaced the throttle body? Anyone know the size of ours? I think its 75mm. I was going to put on an ls6 tb but i believe its the same size?
Old Sep 12, 2011 | 05:12 PM
Hawkins04's Avatar
everything I've read says its a 75mm TB
Old Sep 12, 2011 | 06:03 PM
TheJPGXP's Avatar
The '08s also have a different pin connector from the others, be wary.
Old Sep 12, 2011 | 06:34 PM
Brian396's Avatar
I believe its referred to as a 78mm.
Old Sep 12, 2011 | 10:00 PM
DavidGXP's Avatar
76.2mm bore and 82.55mm inlet that tappers down to 76.2mm. These messurements are outside diameters.
I was searching for a adaptable tb and called a bunch of shops. I was told to use the C5 Z06 TB or any TB that does not use a external TACH.
The ZO6 TB's pinning is different, but the voltage reference points are simmular.
Using the ZO6 TB would eliminate the TB adapter and add a few more hp up top. Plus you could step up to the larger 85mm MAF and tubing.
For people wanting to do this swap.. I have not tried it and do not know for sure if the LS6/Zo6 tb will work!
The Zo6 85mm MAF will work (Re-pinning) but rquires funky pipe reducers due to our small *** TB inlet. Using the Z06 TB and MAF with the right size filter and tubing would be the right way to go. Expensive and un-proven, so use at own risk!
I would rather use the TPiS 90mm LS6 intake with a LS2 TB and LS2 MAF. Search for answers I have this setup all over the place!
Old Sep 12, 2011 | 10:11 PM
DavidGXP's Avatar
And for the record.. even the new 5.3 trucks are using 90mm tb and such now.
Old Sep 13, 2011 | 12:36 PM
I am using a 78mm ls6 intake now. I will probably do a 85mm tb, tubing and maf. The shop is still looking into the details though on it. I will let you know! Thank you David.
Old Sep 13, 2011 | 12:41 PM
how big is the z06 tb you are referring too?
Old Sep 13, 2011 | 02:21 PM
DavidGXP's Avatar
76mm, but the inlet that the inake piping connects to is bigger. We have V6 piping.
You can get a bigger TB for the LS6 intake. They are billet and cost over 400.00
Old Sep 13, 2011 | 02:46 PM
ok thanks, i will let you know what my shop decides to do. They were the ones who rigged up the ls6 intake to look stock so they should be able to do a great job. Fingers crossed for some serious top end hp gains
Old Sep 13, 2011 | 06:15 PM
DavidGXP's Avatar
Cool.
You have been a true LS4 pioneer. Even though I'm a hands on guy, I have been a fan of your build. Keep it up!
Old Sep 14, 2011 | 03:26 PM
yea man you have steadily become my rival lol You took my chance to be the first to break into mid 12s!!!!
I appreciate the help hopefully this one last push to do something new will prove to be worth it. Lets hope i gain like 30hp up top or something lol
Hey maybe we will be able to show that the ls4 can hit 11s NA
Old Sep 19, 2011 | 09:57 PM
molecularmann's Avatar
...hey maybe we will be able to show that the ls4 can hit 11s NA
Old Sep 19, 2011 | 10:00 PM
createnit's Avatar
that would be cool!
Old Sep 20, 2011 | 12:08 AM
JWMayes's Avatar
And then top it with boost to get to low tens, maybe even nines. God, I wish I had the money. I would do it in a heart beat, lol.
Old Sep 21, 2011 | 03:30 PM
So no go on the throttle body. They used a c5 Z06 maf and tb. They got everything installed and physically working but they weren't able to get the computer end of it to work. Apparently the computers are too different.
I did tell them that the new 5.3 trucks use the larger 80mm tb now so they are going to look at that route
Old Sep 21, 2011 | 05:33 PM
neilownz's Avatar
The truck one is closer to 90.
Old Sep 21, 2011 | 09:41 PM
DavidGXP's Avatar
Also your intake opening is only 75-76mm. So there is no point in upgrading to a larger TB.
You should send your intake to TPiS and have them plastic weld a LS2 inlet. Then you could use a LS2 90mm TB. The costs is 350.00. http://tpis.com/parts/view/39
The 799 is for a intake and the LS2 inlet upgrade. Call them and they will mod your intake.
LS2 Inlet, TB, and MAF!
Old Sep 21, 2011 | 10:24 PM
The problem is the wiring doesnt match. My mechanic was saying they use different resistances on the c5 z06 tb.
I am trying a few other things. Like i said they got it all installed and stuff so the fit wasnt a problem. It was just trying to get the motor to work that was troublesome
Old Sep 21, 2011 | 11:14 PM
DavidGXP's Avatar
Of course everything fit. That TB is for that manifold lol.
Seriously, send that manifold off to TPiS. I have been wanting to do it for a long time!
