Hiss between manifold and rear VC
I removed the hose completely, checked it for leaks but didn't find anything. Guessing I should remove the rear VC and see what is going on...
The baffles in my valve covers had to be removed for the 1.85 RR install so I'm not sure how that would be impacting me other than just more oil back into the intake, I really need a catch can though...
Whatever is causing it I'm guessing is making me run lean. I've decreased the MAF Airflow Vs. Frequency probably 5% and I'm still running +9 LTFTs at idle, decreasing almost linearly to +2, 3 at higher MAF Freq. Which basically is no change from the %5 I pulled. This is all after I found and fixed an exhaust leak stemming from the clamp on the rear side of the crossover pipe and the clamp further down. I haven't smelled exhaust yet but every once and a while I can smell it come through the air vents...but I'm also catless though which doesn't make it easy.
Any suggestions here? Anything to look for while scanning that may help narrow it down?
