Trans is being rebuilt. Lost 4th gear and shutter.
Once I got off of the freeway, and came to a stop, the trans decided to shutter thru 1st, till it grabbed 2nd. I have been living with 4th gear woes for quite some time now.. The car was still drivable and snappy till I decided to drive like a grandma.
Took the car into the shop so I'll post what they find. (It's Probabaly the valve body)
Forced to spend bucks now, so there goes my heads
Thankfully I bought parts form Tripple edge last year. I do not blame the shutter or the loss of fourth on my mods. This trans has been a real trooper. 65K with a lot of hard driven miles and over 50 drag strip passes. **** happens, so now it's time to upgrade to my 3400-3800 stall converter with 3.69's.
The service tech said he thinks the torque converted isn't unlocking under those load conditions, but they are going to run some tests on it to see if they can narrow it down.
Seems like most people lose their converters, burn up a drum/clutch or have valve body issues. So far, I haven't heard of any brakage. I am still convinced that a trans cooler, shift kit and regular fluid changes (25K), will preserve the 4T65E for at least 100K.
?????I will let everyone know what the shop finds. With parts and labor (including what I bought from Dave) I will have spent close to 4200. Ouch!
If I had more time, and if it was still summer, I would have pulled the trans myself. I need this car back on the road ASAP, so I was forced to take in.
GM f'ed us on the design and execution of these transmissions, and care (or lack thereof) has little impact on whether you're one of the unlucky ones.
I just wish GM would recall these things and be done with it.
I guess what I was trying to say was, our 4T65 failures are generally not heat related. I do believe every LS4 owner should add a trans cooler because they do get hot, but our transmissions generally don't last long enough between rebuilds to die from heat problems!
The PI converter wasn't machined properly, so the bevel is cutting the turbin shaft
O- ring.
PI is going to build another converter and ship it out ASAP.
I was supposed to get the car back tomorrow morning. I sure hope this new converter works or else it's back to stock!
The builder said the channel plate TCC pressure relief valve was lose and everything else looked really good. Freaking less then 50.00 part was causing problems lol.. I guess I had a lot of slop in the 2nd clutch assembly too. The shop also thinks the TC was going out but without the trans throwing codes, its hard to say without cutting it open.
You have a lot more invested in your car than I do in mine so I see how that wasn't an option.
