Torque Pro, how to decipher to info?
Old Oct 12, 2011 | 06:29 PM
LS4 swap's Avatar
Default Torque Pro, how to decipher to info?
I have the "smart phone" Droid 2 version of the Torque Pro scan tool and know the obvious stuf, but would like to know what "ideal" values for stuff like O2 sensors and and the like. It has a lot of values that I could use if I knew what I am looking for.
Any help would be appreciated.
thanks, Rick
Old Oct 12, 2011 | 09:04 PM
xxtheshockerxx's Avatar
i mostly use it for Trans fluid temp and intake temp
Old Oct 12, 2011 | 09:49 PM
LS4 swap's Avatar
Watch the temp go up as the car sits after a drive, turned off.
The info is extensive and could be VERY usefull to people that know what they are looking at
I drove the car for about 30 miles under several conditions as my wife watched the display and relayed the info to me.
Cool stuff.
Old Oct 12, 2011 | 09:58 PM
LS4 swap's Avatar
The drivetrain I have is out of an 06 Monte Carlo and it did not give my a trans temp?
Old Oct 12, 2011 | 10:02 PM
you gotta load the gm pids and put in "7E2" in the header
Old Oct 12, 2011 | 11:46 PM
LS4 swap's Avatar
You just lost me?
Can you walk me thru that some how?
What is a pid and were do I get them?
Where is the header?
Old Oct 12, 2011 | 11:56 PM
go to settings
scroll all the way down to manage extra PIDs/sensors (whatever yours says mine might be different since i have pids loaded)
it should pop up asking what pids you want to load pick GM.
once the list loads find transmission fluid temp 3/4ths the way down the list.
click on it and scroll to the bottom and enter the header
that should give you a good idea of how to set it up. i may have missed a little here and there but you should get it
Old Oct 13, 2011 | 12:00 AM
LS4 swap's Avatar
Thanks, I will see what I can do
Old Oct 13, 2011 | 12:06 AM
LS4 swap's Avatar
Does not list any pids to choose from?
OK, got. BUT it has two options method one and method two?
Old Oct 13, 2011 | 11:41 AM
Doesn't matter what one you chose. Just make sure when u put it on a screen to choose the method you set up
Old Oct 13, 2011 | 11:50 AM
94ss06gxp's Avatar
which OBD connectors are you guys using? sorry for the thread jack.
Old Oct 13, 2011 | 03:42 PM
i got a cheap $20-$25 one off ebay and it works great
Old Oct 13, 2011 | 07:55 PM
LS4 swap's Avatar
I have the PLX that Droid recomends for the Torque Pro. I dont know if the PLX is better than the others or not, I just know the system is realy cool. The PLX is $100 and some others can go for over $200. The expensive ones allow you to access the the brake and traction codes.
Old Oct 13, 2011 | 07:57 PM
LS4 swap's Avatar
I am still having issues?
I dont think the PID is loaded? I still do not have a trans temp and the speedo if off by 10mph?
