Trans Service Question
I know changing the fluid isn't going to fix it. I am a firm believer in these transmissions are going to break it is only a matter of time. So the real question is, is it worth the money to spend on the fluid change?
Thanks,
John
I change my fluid every 25-30k miles. Don't do a flush though, just drop the pan and let it drain out. Need about 8 quarts of Dex VI and a new filter. You should install a tranny cooler as well.
Thanks.
Thanks
I got your message over on GMLS4...You should drop the pan and do a fluid change, but I suspect that you're going to find bits of torque converter clutch material in it. This is exactly what mine did when it died the first time. You might be able to buy yourself some miles with a fluid change, but the damage is already done. The TCC is wasted and the resulting material is now flowing through the trans which is damaging the clutches.
Good luck and let us know how it goes.
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Ours is 99% highway, but it didn't matter.
We have 44,000 on the TEP-fortified rebuild with no problems (knocking wood) and are hoping to get it to 100,000, which would mean 187,000 on the car. If all goes well, that will be sometime in mid 2013, at which time we will rid ourselves of this costly mistake!
I could be looking at this the wrong way though. I might be better off walking away. I always say I should have bought a Bonneille SSEI...
