Lost tpms and remote
Old Jan 8, 2012 | 02:35 PM
badata's Avatar
Default Lost tpms and remote
Lost both my tpms and my remote control door locks. Guessing its the module reciever. Anyone know the location and or fuse. At least my check tire pressure stopped popping up.
Old Jan 9, 2012 | 10:03 AM
redlightrampage's Avatar
Does any part of the key fob work? If yes, it sounds like the body control module. TPMS doesn't have anything to do with the receiver unless by receiver you mean the entire BCM. They are both integrated into BCM ultimately.
I would check the obvious first and pop off the cover on your key fob and see if the battery clip detached. If that's the case you have two different issues, just resolder and go. If the clip is good try replacing the battery.
If that doesn't work I'd guess it's the BCM or related wiring.
Old Jan 9, 2012 | 10:36 PM
badata's Avatar
No my control has no function at all. I checked and changed the battery. I thought they both used the same antenna and reciever.
Old Jan 10, 2012 | 06:39 PM
Hmm yeah you are probably right then. Failed to realize TPMS was wireless but it doesn't make sense to be a wired system lol
