Factory Remote start question
Old Feb 6, 2012 | 06:10 AM
SSWHITE07's Avatar
Default Factory Remote start question
How long does it stay running for? It doesn't seem long enough to get it warm on a really cold morning. Is there any way to keep it on longer?
Old Feb 6, 2012 | 06:52 AM
baltsk8er69's Avatar
It runs for 10 minutes then shuts off. At any point In time while its running if you initiate the remorse start sequence again it will restart the 10 minute timer but only once. After that you will have to put the key in the ignition before you can use the remote start again. For example if you remote start the car and wait 5 minutes before hitting the remote sequence it will go for 10 more minutes netting you 15 total. If at any time you hit just the remote start button not the lock button first it will shut the car off. And just for ur info....less than 35 farenheight will initiate heat and defrosters greater than 90 will initiate ac. Anywhere in between will turn on what ever you left it on.
Old Feb 7, 2012 | 07:59 PM
redlightrampage's Avatar
BCM stores the code, so no go there. Easy fix if accessible.
