To wheel or not to wheel?
Old Mar 30, 2012 | 08:26 PM
DavidGXP's Avatar
Default To wheel or not to wheel?
It's tire time so
I think am going to rock my Enkis NTO3+M's for the summer with the Nitto's
I just put them on a few days ago, and am pleased with traction. I would like to order some 18x7.5's for the rear that will be wrapped with http://www.tirerack.com/tires/tires....el=G-MAX+AS-03 225/50-18
The Enki's weigh 18.5lbs per wheels Vs. 26 per Alcoa. The Enki's are 18x9.5 and the tires are 285/35/18 NT555R's. The tires handle very well in the rain!
Here is a pic of my wheels mounted.. I need to get some center caps.
Need to be shinned!
Should I Run the Enki's or powder coat my stock Alcoa's and wrap them with new rubber? I don't wanna do the whole Plasti dip thing
Powder coating the Enki's is not an otion lol.. Either way, I am looking a 1000.00
Opinions???
Old Mar 31, 2012 | 09:25 AM
JessmoMonteSS's Avatar
You have a strong unning GXP so I would go with the lighter wheel. The alcoa's look better (especially powder coated) but would put on ~30lbs. With your setup, it's a no brainer IMO.
Old Mar 31, 2012 | 09:43 AM
Dom87SS's Avatar
looks kinda mean, i like how low it is. wish my came down to that level.
Old Mar 31, 2012 | 05:57 PM
rm08gxp's Avatar
My personal opinion is they look horrible. but, performance over appearance makes sense to me.
(sorry)
Old Mar 31, 2012 | 06:06 PM
99slpws6's Avatar
I don't like the look its to bland for the car. A set of weld racing rt would look amazing on your car.
Old Mar 31, 2012 | 09:37 PM
steves ls6's Avatar
Go with the lightest wheel tire combo. I just ordered new tires for my GXP I went with these
http://www.discounttire.com/dtcs/fin...Form&rc=ILCINT
They weigh a few pounds less than the stock ones. Or michelin Super Sports in a 275 45 18 weigh even less (25lbs??). They supposedly are one of the best.
Old Mar 31, 2012 | 09:58 PM
BlackImpSS's Avatar
I'd keep them. The rims don't look all that bad and the 555r are great tires. My buddy has had his set on his TA for over 2 years with plenty of burnouts at the track. DDs it from spring until storage time. He's went 12.20 cut a 1.68 60. After all the abuse they still have 1/2 thread life. There a great alt b/w a true drag radial (et street, nt05R) and street tire. They just need a lot of heat to hook well. That set of tires also made another TA go from 13.4 to 12.21 with a 1.9x 60. They swapped tires before we headed to the track.
Old Mar 31, 2012 | 10:13 PM
DavidGXP's Avatar
I have only used theses wheels and tires at the track. I have never driven with them on the street until now. I am so impressed with the feel. The steering is super responsive and the traction is incredible. I personally like how the wheels look, and they would look even better with caps and a shiny side wall.
I really have no choice but to run them, cause I need all the traction I can get with 3.69s. I am starting to think that they hook better with 30psi then with 16psi that I used at the track.
Old Apr 1, 2012 | 07:21 PM
DavidGXP's Avatar
Nice car man! What is your offest?
Old Apr 1, 2012 | 11:09 PM
LS1 Racing's Avatar
Originally Posted by brikki8109
I bought some take off 18x8.5 bullitts for $650, sold the Alcoas for $400, and couldn't be happier!
Good looking wheels....Very similar to the Smoothie IIs I have on my Camaro. I'd powdercoat 'em black and be done with it!
Old Apr 2, 2012 | 01:18 PM
DavidGXP's Avatar
Those rts Weld wheels are king ****! They don't offer our offset though.. The 5x115 are available for in offsets for dodges. We need a minimum of +35 in order to look good. Plus, those wheels are over 600.00 each. For that price (2400-2500) I would put on a rear mount
Old Apr 2, 2012 | 01:22 PM
DavidGXP's Avatar
For those inquiring about my stance, I am using ssc springs from cunuck. 2.5 drop.
Tires are 285/35/18 on a 9.5" wheel +40mm offset No rubbing or rolled fenders!
Old Apr 2, 2012 | 04:15 PM
ImpSS07's Avatar
David, if you don't mind me asking. How much did you pay for those Enkis? I looked them up and found them at about $260ish a wheel, Does that sound right?
Old Apr 2, 2012 | 06:22 PM
DavidGXP's Avatar
Yes 260 is about right
Old Apr 3, 2012 | 09:09 PM
99slpws6's Avatar
Davidgxp has does you car ride/handle with being that low
Old Apr 3, 2012 | 10:44 PM
V8ImpSS's Avatar
those enkei's dont look bad at all, if it weren't for that ring, I'd really like them. at first glance I did like them. if they're going to save you a ton of unsprung weight then I'd say run em. but if YOU don't like the way the look, then powder coated alcoa's look real nice too.
why not sell your enkei's if you don't like them and pick up ones that are already black, or maybe gunmetal looks cool too IMO Lookie Here
oh yea, and for your rear tires, why not go for a 225/55-18 and put some more weight on those front wheels, My Blizzak's in that size barely fit with the stock +52 (18x7) SS wheels so you should be fine with almost any wheel
ALSO, sorry to thread jack but do you think 285/35-19's would fit? or maybe 275/35-19's? so they'd have a half inch bigger radius. I have the SSC 1.7 drop in front so I've got a bit more room vertically.
thanks ahead of time, your the man
