Gxp won't run
Old Jun 18, 2012 | 12:00 PM
jsmith309's Avatar
Default Gxp won't run
2006 grand prix GXP won't run!! I have fuel pressure! It just won't fire when cranking! My fiance was driving it and it just cut off on her. I was told it should be the crankshaft sensor. Any other suggestions??
I bought The car may 20th.
Since then ive replaced the alternator, tensioner pulley assembly, serpentine belt. The a/c went out last weekend and now this.
Old Jun 18, 2012 | 01:35 PM
JessmoMonteSS's Avatar
It sounds similar to symptoms of a bad crankshaft sensor. Was there a check engine light for it? Does it start when cold? The ones I've come across usually will start when the vehicle is cold but once it warms up it will die and when you try to start it back up again, it just cranks and cranks.
Old Jun 18, 2012 | 03:09 PM
jsmith309's Avatar
Just let it sit overnight and tried to recrank it. No fire
Old Jun 18, 2012 | 04:02 PM
Any check engine lights?
Old Jun 18, 2012 | 04:54 PM
BlackImpSS's Avatar
How many miles? Pull a front plug and make sure your getting spark too.
Old Jun 18, 2012 | 11:21 PM
jsmith309's Avatar
Angry
Not getting spark. My only code is p0118
Old Jun 19, 2012 | 06:06 AM
Ill_Born_ss's Avatar
ECT (engine coolant sensor) has failed in the over temp position.... the nannies are protecting you! Replace the sensor with a GM original. You may get it to start by disconnecting the sensor, but other things will not function properly until it is fixed properly.
Old Jun 19, 2012 | 11:44 AM
MillerMonteSS's Avatar
This happened to me in my Monte. When I put the key in the 'On' position, your temp gauge went all the way up and the fuel gauge went all the way down. I used a handheld scanner to get me off the side of the road by resetting the codes after I was SURE I wasn't overheating. After I replaced the sensor, it was good to go.
