Shifter stuck in park on 06 MonteSS
I went ahead and just pulled the cup holder and hit the release button under console and have been driving it like this.
What I have read is that the wires inside the shifter buttons get pulled out on our LS4 gen cars but I have not verified this. I also manually unhooked the brake pedal module thing from the pedal linkage and tried moving that around while my father tried turning key with no luck.
Any one else have suggestions?
Thanks!!!
If I release the brake a bit more gradually, I don't have this problem at all. Also, it has never happened on level ground. Hope this helps!
1. Access the solenoid on the shifter.
2. Press and release the shifter while listening for the solenoid to move.
3. If it does not, Test for 12 volts on the Dark Green/White wire in terminal B at the solenoid with the brake applied.
4. Test for ground on the Black wire in terminal A.
5. If ok, the solenoid is defective.
common issue is wiring at shift solinoid broken. replace connector
