Brake Fluid Change
Old Jul 11, 2012 | 05:14 PM
kweevuss's Avatar
Default Brake Fluid Change
I was thinking about doing a flush on the brake system. I was wondering what DOT fluid I have to use. Is DOT 4 ok or what should it be?
Old Jul 12, 2012 | 03:43 AM
91parkave's Avatar
Moderator
Dot 4 is more than adequete
Old Jul 12, 2012 | 06:22 AM
Panther427's Avatar
Dot 3 should have been standard. Dot 4 will be an upgrade higher boiling point.
Dot 5 should never be used in a car with ABS
Old Jul 12, 2012 | 09:07 PM
Sadden's Avatar
Dot 5 should not be used on pretty much any car. As it is desgined for motorcycles and uses silicone as opposed to glycol.
Dot 5.1 is compatible with cars. As it is glycol.
Old Jul 12, 2012 | 09:08 PM
kweevuss's Avatar
Ok it sounds good, thanks for the info
Old Jul 13, 2012 | 09:29 AM
El Cid's Avatar
The owners manual states:
"DelcoŽ Supreme 11 Brake Fluid or equivalent DOT-3 brake fluid"
Hope this helps.
