DTC Help
Old Jul 25, 2012 | 05:55 AM
indynotch50's Avatar
Default DTC Help
Hey all,
I have a few threads on this already but I still need some help.
I am wondering if anyone has any suggestions or has seen this before.
When I would start my car all the abs, traction control, stability lights would go off. I replaced the front left hub on Saturday. The lights would still come on, but it is now after driving. I ran by auto zone and they went ahead and put it on the scan tool. It was giving a C0038 (or C0035) code: Left front speed sensor.
After driving it a few more days I have some more information on the symptom.
I can drive to work, 54 miles, no problem, but as soon as I pull in the parking spot all the lights will trip. If I turn and accelerate from a stop sign, it will go off. It appears as though any low speed, sharp turn will set it off, but not always.
I went through the harness and didn't find any breaks.
My plan tonight or tomorrow is to go through and check some pins.
Anyone have any other ideas? Could it be the EBCM?
The only other "odd" thing it is doing that would be related is that when I put the car in park after driving, sometimes the driver's door or the driver's side rear door will not unlock.
Any help is much appreciated guys.
Old Jul 25, 2012 | 12:47 PM
91parkave's Avatar
Moderator
Or u just got a hub with a defective sensor....if the harness is intact and solid in the connectors then u should be golden if urestill tripping ABS lightsi would exchange the hub for another one
Old Jul 27, 2012 | 05:46 PM
Tpattsgxp's Avatar
Or the sensor was damaged during the process.
