Ipod jack
Old Sep 17, 2012 | 05:38 PM
07 GXP's Avatar
Default Ipod jack
Has anybody put and Ipod jack into a Monsoon system? I have a 07 GXP with the 6 disc Moonsoon system. I have seen other threads but not one directed at this head unit.
Old Sep 17, 2012 | 07:31 PM
DuronClocker's Avatar
The Impalas got them stock
Old Sep 17, 2012 | 08:55 PM
kweevuss's Avatar
http://www.grandprixforums.net/how-a...-xm-21849.html
Look like this would work. I haven't done it myself, but in the spring when I get my car out of storage i'm going to try it
Old Sep 17, 2012 | 10:31 PM
07 GXP's Avatar
Thanks for the replies, I don't have XM either. Forgot to mention that in the post. I'll try it and see if it works.
Old Sep 18, 2012 | 07:34 AM
Brian396's Avatar
I did this and it works good, sound is cristal clear. The only thing is the head unit says XM preview or something. There are some other options out the that are nicer but a lil mo money.
Old Sep 18, 2012 | 11:57 AM
76_iron's Avatar
I'm going to do this, my radio shack only had three wire jacks but I don't need the xm to work so I think it should work.
Old Sep 18, 2012 | 08:23 PM
fubar569's Avatar
I did the USA Spec IPOD interface on mine. Mine is a 08 with single disc monsoon and XM - i can confirm the factory XM still works, the HUD works, the dash panel works, steering wheel controls for track skip work, etc.
I installed the wire under the carpet and into my center console. barely long enough with the box installed in the deepest part of the trunk in the middle of the car against the back seat. This also provides for a standard 1/8" (RCA) line in as well as a legit ipod connector.
Sometimes the info on the HUD is displayed incorrectly...like it hangs on a different source than the aux but plays fine and sometimes the song titles won't display or are incorrect...but the steering wheel track skip and volume work and THAT was the most important thing to me.
http://www.crutchfield.com/p_581PA15...GM.html?tp=120
that is the one i used. it lists my car as incompatible but i assure you it works with my combination.
Old Sep 18, 2012 | 08:28 PM
kweevuss's Avatar
I thought the 6 CD player had XM? maybe I'm thinking of that aux button on the radio that does nothing.. Its been a while since I sat in my car
Old Sep 19, 2012 | 10:52 AM
Rob's Avatar
Rob
I used this:
http://www.kawal.net/PAL%20Rev%202.htm
Works like a champ and easy to install.
Old Sep 19, 2012 | 07:47 PM
07 GXP's Avatar
Just an update on the Ipod jack install......Looks great in the trim piece around the radio but doesn't work. My 6 disc isn't XM or XM ready and I think that's why it doesn't work. Question.....what does the 12 pin plug on the back of the radio go to? That's where all the write ups tell you to hook to. I hooked everything up just like they all say to......triple checked every connection and still nothing. I called the Chevy dealer and he couldn't tell me what the 12 pin plug goes to. Everything on my radio and steering wheel controls still works fine. I plug it in and try using the CD AUX button and that just changes the radio to the CD player. Even with the wire plugged into the jack and the Ipod playing it doesn't effect anything. That is really weird because you cut and splice 2 wires. I'm confused as all hell.
Old Sep 20, 2012 | 07:55 AM
Brian396's Avatar
Push the band button, it'll go from fm, am, then to xm preview. If you did it right the jack will work on xm preview.
Old Sep 20, 2012 | 10:28 AM
07 GXP's Avatar
Don't have XM or XM ready Monsoon only 6 disc. The band button will not do it nor will the CD AUX button.
Old Sep 20, 2012 | 03:57 PM
Brian396's Avatar
Well crap I have no idea what you did then?
Old Sep 20, 2012 | 03:58 PM
07 GXP's Avatar
What in the hell does the 12 pin black plug go to????
Old Sep 22, 2012 | 07:14 AM
07 GXP's Avatar
Update #2.... I will be swapping my 6 disc out for a single disc with XM. Hope this works.
Old Oct 8, 2012 | 08:03 AM
WantanLS4's Avatar
I plan to try this with the radio shack part soon.
Old Oct 8, 2012 | 08:14 AM
07 GXP's Avatar
Just to let everyone know... If you don't have XM this mod will not work. I changed the head unit and that didn't work also got my buddies XM receiver out of his car and made a harness for it and still nothing. Save the time and just get the adapter.
Old Oct 8, 2012 | 08:30 AM
WantanLS4's Avatar
I have the 6 Disc XM.
Old Oct 8, 2012 | 04:38 PM
Brian396's Avatar
Sorry about that. I feel like I screwed you over a little. I thought XM was standard and you just didn't have it turned on.
