Gears
Old Oct 4, 2012 | 11:51 PM
SleeperGXP's Avatar
Default Gears
Any recommended place to get gears and what gears would u recommend? And does my tranny have to be dropped for them to be installed ?
Old Oct 5, 2012 | 08:33 AM
blkchevyz's Avatar
its not like a rear wheel drive car where you can just swap out a ring and pinion, think of it more like a timing set.
pretty sure the whole transmission needs to be taken apart to even get to where they are located... its a mod best left for when your doing a rebuild.
Old Oct 5, 2012 | 10:42 AM
The_Madcat's Avatar
TripleEdgePerformance sells the parts you would need for the gear swap. Yes, you need to drop the trans.
Old Oct 5, 2012 | 02:48 PM
SleeperGXP's Avatar
Damnit I just had mine built and a shift kit installed just didn't have the funds for gears then
Old Oct 5, 2012 | 09:58 PM
neilownz's Avatar
3.29 or whatever stock is decent overall. Bigger might help the low or just make you spin the wheels.
