squeak from font left
Old Jan 4, 2013 | 03:30 PM
gagt3100's Avatar
Default squeak from font left
So there is a squeak coming from my left front wheel. It squeaks when I either come to a stop or take off from a light. it does not matter if the brakes are on or not. It does it when I am going about 10 mph or less. it does not matter which way the wheel is turned or if its turned at all.
I think it is a wheel bearing but im not 100%
http://s282.beta.photobucket.com/use...O0196.mp4.html
Old Jan 4, 2013 | 04:11 PM
Mikuni_03's Avatar
You sure your brake pads aren't gone? Sounds like it to me.
Old Jan 4, 2013 | 05:31 PM
91parkave's Avatar
Moderator
Wheel bearings don't squeak anyway. I'd look at ure pads and ensure your caliper pins are lubed
Old Jan 6, 2013 | 02:07 PM
gagt3100's Avatar
Thanks for all the thoughts, Ill take them off tomorrow and look at them and get back to you guys. It rained/snowed yesterday and it was less loud/frequent.
Old Jan 6, 2013 | 08:36 PM
gnjoe's Avatar
Look behind the rotor under the wheel hub. There are two metal tabs that may have come in contact with the rotor. I had that exact issue with mine. Slightly bent them so they didn't touch and the noise disappeared.
Old Jan 6, 2013 | 09:21 PM
rm08gxp's Avatar
x2, i cut the tabs off with a grinder but same deal
Old Jan 7, 2013 | 12:55 AM
gagt3100's Avatar
Will do tomorrow! ill try to take some pics too
