Cylinder #5 misfire
Old Jan 23, 2013 | 04:53 PM
SDGTP99's Avatar
Default Cylinder #5 misfire
Hey all, I joined not long ago & haven't really posted much yet. I've got a 2008 GP GXP back in August & just recently it started having loads of misfire in Cylinder #5. It only seems to do this around 40mph or higher, & not at idle. I've pulled that spark plug out and it looks just fine. What could be causing this misfire? Any thoughts, comments, suggestions?
Old Jan 23, 2013 | 06:49 PM
Ill_Born_ss's Avatar
REMOVE and clean your induction system
-MAF spray cleaner(MAF sensor cleaner or electronic component cleaner) and toothbrush, dont touch the actual sensor with anything but the spray
-TB remove and clean using throttlebody cleaner, apply a thin layer of vasaline or die-electric grease to seal proir to re assembly
be sure to reassemble all connections tight and you can apply a little of the vasaline inside any of the vacum lines( look in them you will see an oring in there, lubricate it)
Should take less than an hour
Old Jan 23, 2013 | 08:33 PM
lVloses's Avatar
Could it be a wire? Bad coil pack? Fuel injector? If you haven't replaced the plug, you could just see if it was a bad plug.
Old Jan 26, 2013 | 11:18 AM
rm08gxp's Avatar
Agree, Clean your MAF. How many miles? Any other CEL codes?
Old Nov 18, 2013 | 09:08 AM
JR 427's Avatar
Ever figure it out? I am having a similar issue.
Old Nov 19, 2013 | 02:15 PM
Mr.Angry.GXP's Avatar
check your coil packs, i had a missfire on #5, switched it to #1 and it happened again on #1, checked for spark and continuity and replace the one pack... never one issue since
