45 mm offset
Old Feb 6, 2013 | 03:19 PM
SatanBob's Avatar
Default 45 mm offset
That should be a close enough offset on a Monte right they are zinik rims 18x8
Old Feb 7, 2013 | 03:45 PM
2006 Silver Monte SS's Avatar
That should work fine. That offset is 7mm (.27") further out than stock. Add .50" for the wider wheel. Total movement to the outside would be about .75", which is not going to cause an issue.
I currently have 1.5" spacers on the stock rear wheels and it only rubs on major dips...you have plently of room with that offset.
Old Feb 8, 2013 | 02:35 PM
SatanBob's Avatar
Alright thanks man
Old Feb 8, 2013 | 03:06 PM
Bryan921SS's Avatar
Hey Silver Monte SS did you add those 1.5 inch spacers just to make the wheels outer edge flush with the fender, or did you widen the stock wheels?
Old Feb 8, 2013 | 04:01 PM
Just wanted to make the wheels sit flush with the fenders...stock wheels & tires. I added 1.0" spacers on the front to accomplish the same. Now the car could stand to be lowered about 1-1.5" or so.
Would look like the factory should have designed it.
Old Feb 10, 2013 | 05:38 AM
SatanBob's Avatar
How much did those cost man?
