LS4 to LS2/3/7 throttle body thread
Old May 29, 2014 | 04:08 PM
xxtheshockerxx's Avatar
anyone know if an ls2 TB from a TBSS would be the same thing as far as the wiring and that goes?
Old Jun 3, 2014 | 07:34 PM
2008impalaguy's Avatar
so let me get this straight, if i have the six pin, there is no need to re pin, itll plug right up and just needs to be tuned?
Old Mar 21, 2017 | 10:00 PM
bruhaba's Avatar
Default confirmed
For what it's worth, I have a 2006 Chevy Trailblazer which is supercharged with an Eaton M112. Uses what looks like the same throttle body as the LS4(75mm blade). I swapped to a silver blade successfully using the diagram in this thread. GM #12570790 used on 05-08 corvette I think...
Thanks Gentlemen!
Old Sep 21, 2023 | 08:51 PM
Tgek_76's Avatar
Default Ls4 to ls3
Trying to get a ls 3 throttle body to work on a 2006 5 3L Ls4.. anyone have info?? Can it be done by re pinning thr connector?
Old Jan 2, 2025 | 05:48 AM
DarkSky's Avatar
I just ordered a 102mm DBW throttle body as part of a FAST LSXr induction upgrade on my (2005 GTO) LS2. Hope to bench test it before taking the car apart. If I had a PWM signal generator, how would I configure it (in terms of frequency & pulse width) to verify proper throttle body operation?
