Brake Assist
Old Apr 30, 2013 | 09:46 AM
crich88848's Avatar
Default Brake Assist
So I was on my way to work this morning when I got stuck behind a bus. The bus eventually started to make a left hand turn so I jumped over into the emergency lane to get around him. I got over, punched it, and everything cut out like the traction control kicked in, only it didnt. Then up pops the Service Brake Assist. Anybody got any ideas??? Thanks in advance.
Old Apr 30, 2013 | 01:32 PM
TheMonteMan's Avatar
if there were rumble strips and you blew through them real fast perhaps the vibration knocked a connection loose.
Old Apr 30, 2013 | 02:24 PM
crich88848's Avatar
Do you know where these connections are at so I can check them? And what exactly is the brake assist?
Old Apr 30, 2013 | 06:01 PM
Str8BlkSS's Avatar
Check your brake fluids
Old Apr 30, 2013 | 06:05 PM
crich88848's Avatar
is that what it means by brake assist, the brake fluid "system?"
Old May 1, 2013 | 08:57 AM
bignosecaveman's Avatar
check wiring harness to your abs sensors, possible loose or broken wire. When you turn the steering it is bending/flexing the wire.
