Modding Advice....
Old May 12, 2013 | 09:10 PM
Mr.Angry.GXP's Avatar
Default Modding Advice....
I need some help deciding what set up to have, i know i want the Cartunning turbo kit.... and want a Cam, as well and an exhaust cutout, as for the cam, i want something with a nice lope, what cam would you guys suggest? and rockers? what would be all the supporting mods? i know that a TEP trans is on the list! lol
Old May 13, 2013 | 09:11 AM
Bryan921SS's Avatar
If you go with a cam you won't need rockers.
Has anyone done a cam and the Cartuning kit?
Old May 13, 2013 | 12:12 PM
batboy's Avatar
The typical supporting parts for a cam swap are better valve springs and hardened pushrods.The pulley bolt is TTY, so you need a new one and I would also get new front seal, timing cover gasket and water pump gasket. If you have a few miles on the motor, you might also want to get a new timing set and oil pump. You do know you pretty much have to pull the engine to do the cam swap, right?
Old May 13, 2013 | 03:59 PM
I figured I might have to pull the motor, and agreed, has anyone ran a cam with the cartunning turbo kit? And what cam would be sugguested? I want something with a nice lope to it, I'm still kinda new to the LS4 world
Old May 13, 2013 | 08:05 PM
Brian396's Avatar
Do the trans 1st.
Turbo 2nd.
Then the cam if you want.
I came across this the other day.
https://ls1tech.com/forums/forced-in...urbo-cams.html
If I was to do a cam I'd probably have Pat G spec one.
