Hubs/Wheel Bearings
Well out of all of the expensive brands, my advice would be to go with SKF. The reason I say this is because the fronts have an exclusive "X-Tracker" technology which can be read about here: http://www.vehicledynamics-expo.com/...gizshevket.pdf
The vehicle in question from that test was the STS-V. Some more, official, information on X-Tracker can be found here: http://www.skf.com/binary/12-61238/457891.pdf
• Allows the wheel to run truer during cornering and acceleration.
• Reduces deflection of the hub face and wheel, which provides better steering, handling and vehicle dynamic behavior.
• Reduces brake wear due to true running of rotors, which helps reduce brake warranty costs.
• Improves both NVH (noise/vibration/harshness) characteristics and bearing performance.
As for the rears, I would say SKF again. One reason would be so as to not mix manufacturers. Another would be because the rear SKF hubs I received were made in the USA (the fronts were made in Korea). And finally, they're on their third design: http://www.skf.com/us/industry-solut...t-3/index.html
Sure Timken is on their third generation hub bearing as well, however, I would tend to stick with a company that went out of their way to come up with something as robust and intuitive as "X-Tracker."
I picked up my fronts (BR930548K) for ~$98 each and the rears (BR930075) for ~$93 each from eBay (free shipping).
EDIT: Those hubs can be had cheaper on the seller's website. $90.92 each and $87.70 each respectively. That's a $22 difference; free shipping too.
