Poly Trans Mounts
Old Oct 1, 2013 | 01:15 PM
TML529's Avatar
Default Poly Trans Mounts
Does anyone make poly Trans Mounts for these cars specifically an 08 GP GXP???
Old Oct 1, 2013 | 04:33 PM
91parkave's Avatar
Moderator
The mount Zzp makes works for 3800 and ls4 platforms
Old Oct 1, 2013 | 08:51 PM
TML529's Avatar
I emailed them today and they said that the only mount that is compatible is the Dogbone front mount.
Old Oct 1, 2013 | 10:08 PM
91parkave's Avatar
Moderator
the transmission mount fits its been done already if you dont believe me look on theire own website and look under comments you can see where GXP owners installed the same mount with no issues. dont forget to also search this website too IIRC there were also a couple of members who installed it. I choose to build my own mount
Old Oct 1, 2013 | 11:10 PM
TML529's Avatar
Good Deal. Thanks for the info!!!!
Old Oct 3, 2013 | 10:23 PM
gagt3100's Avatar
Ok this is somewhat correct. There are 2 transmission mounts, there is one on the driver side that can be replaced and upgraded to a poly mount, it looks like a "H" . The other mount is on the passenger side and they do not make poly mounts for those, that one is the one that usually breaks. ZZP will tell you that it will fit and that they have one but don't believe them they only think that our cars have 1 transmission mount. IDK what their deal is over there but thats how they got me, they said it was for the passenger side but it was the driver side one. Hope this helps, good luck
Old Oct 4, 2013 | 01:24 AM
91parkave's Avatar
Moderator
the passenger side mounts are classified as motor mounts onlyx2, driverside like you said is the H
Old Oct 4, 2013 | 03:16 AM
TML529's Avatar
Thanks for the info. I just went back with the OE mounts.
